A wireless mouse that delivers a better mix of precision and comfort--with designed-for-Web scrolling and a feel-good, contoured design.
Micro-precise scrolling
Designed for how you use the Web, our newest micro-precise scrolling makes reading your Facebook® or scrolling through Google® searches easier. Plus, tilting the wheel moves you backward or forward on the Web
Hyper-fast scrolling
Your spreadsheets and documents are getting longer. Your digital photo and music libraries are bursting at the seams. And you're glued to long Web pages that have you scrolling and scrolling and .... To get through it all, you're doing a whole lot of scrolling. We're talking 26 feet of it in your average eight-hour day, according to a Logitech study.
That's where hyper-fast scrolling comes in.
When you need to do some long-distance scrolling, hyper-fast scrolling unleashes the speed demon inside. What's going on under the hood? The ratchet-scrolling mechanism you're used to retracts so the wheel can spin with virtually no friction.
Seven seconds. That's how long some of our scroll wheels spin freely--speeding you through hundreds of pages or thousands of rows.
And, oh yeah, it's got precision handling too. With normal click-to-click scrolling, you can navigate your lists, slides, and images with the line-by-line control you need.
Comfortable contoured design
Based on the best-selling shape in the world, the contoured shape with textured rubber grips keeps your hand happy--even after long hours.
Up to 18-month battery life
The long battery life virtually eliminates the hassle of changing batteries. Smart sleep mode saves power, while an indicator light eliminates surprises
Logitech Unifying Nano-receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless device--without the hassle of multiple USB receivers.
Logitech Advanced 2.4 GHz wireless
You get the reliability of a cord with wireless convenience and freedom--fast data transmission and virtually no delays or dropouts.
Logitech Advanced Optical Tracking
From surfing the Web to navigating your Facebook with precision clicking, pointing and dragging, everything you do on your laptop is just easier thanks to our advanced tracking technology. And you don't need a mouse pad either.
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice at a price you can afford--plus a three-year limited hardware warranty
Perfect for laptops and netbooks
Your mouse works with Windows®, Mac® and Linux®. No matter what type of computer you own today--or buy tomorrow--you can depend on your mouse to work like you expect.
SMALL BUT MIGHTY
Get work done anywhere with this small portable mouse. The size of M325 makes it great for users with smaller hands-including kids-or limited workspaces. The micro-precise scrolling and tilt wheel provide you the speed and accuracy you need. Easy-to-use and compatible with all of the main OS, it's ready to work in seconds and lasts up to 18 months Battery life may vary based on use and computing conditions. without changing batteries -
COMFORTABLE SHAPE, COMPACT DESIGN
Stay productive longer thanks to the comfortable, contoured shape that follows the natural curve of your hand. Compact and wireless, M325 fits easily with your laptop in a bag-making it great for working on the go and homeschooling. It's also designed for both right- and left-handed users, allowing you to switch the left and right click via Logitech Options Software -
FAST SCROLLING, PRECISE TRACKING
Our micro-precise scrolling and tilt wheel give you the speed and precision you need to breeze through long pages, websites, links, spreadsheets, and images. Customize the tilt action to perform horizontal scroll, forward/backward, and more through Logitech Options -
PLUG & PLAY SIMPLICITY
Simply plug the USB receiver into your computer or laptop to start working in seconds and get a strong, reliable connection within up to 10 meters Wireless range may vary based on user, environmental and computing conditions. . Plus, you can easily pair through the same receiver up to six compatible peripherals using Logitech Unifying technology -
BROAD COMPATIBILITY
M325 is compatible with most OS-Windows , macOS, Linux Customization of the buttons via Logitech Options is not possible on Linux. . And is also a certified Works with Chromebook This product has been certified to meet Google's compatibility standards. Google is not responsible for the operation of this product or its compliance with safety requirements. Chromebook and the "Works With Chromebook" badge are trademarks of Google LLC. product -
INCREASED PRODUCTIVITY
Get more done by combining M325 with your laptop. According to a recent study, laptop users who chose this mouse over a touchpad were 50% more productive Based on throughput computation in bits/second combining speed and accuracy averaged for all devices participating in the study. Logitech Ergonomic Lab study on 23 participants in (Oct / 2019) with two Logitech standard mice and two standard, embedded trackpads and worked 30% faster Based on bits/second for averaged movement time for all devices participating in the study. Logitech Ergonomic Lab study on 23 participants in (Oct / 2019) with two Logitech standard mice and two standard, embedded trackpads -
QUALITY YOU CAN RELY ON
The mouse is built with the same high quality standards that have made Logitech the global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. . Durable and reliable, M325 also works up to 18 months Battery life may vary based on use and computing conditions. without changing batteries thanks to the on/off switch button and auto-sleep power-saving mode -
DECADES OF DESIGN EXCELLENCE
We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
- Logitech M325 - Color Collection Limited Edition - mouse - 2.4 GHz - light grey
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Light grey
- 5.7 cm x 9.8 cm x 3.9 cm
- 88 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Tilt Wheel technology, on/off power switch, Logitech Unifying receiver
- Battery
- 1 x AA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- 5.7 cm
- 9.8 cm
- 3.9 cm
- 88 g
- Light grey
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- Buttons Qty
- 3
- 1 x USB - 4 pin USB Type A
- AA type
- Installed Qty
- 1
- Run Time (Up To)
- 18 months
- OS Required
- Limited warranty - 3 years
