Logitech Wireless Mouse M325 - Mouse - optical - 2.4 GHz - USB wireless receiver - light grey
Reduced Price - Whilst Stocks Last!
Quicklinx: 7V78WS00 Mfr#: 910-002334
A wireless mouse that delivers a better mix of precision and comfort--with designed-for-Web scrolling and a feel-good, contoured design.
Micro-precise scrolling
Designed for how you use the Web, our newest micro-precise scrolling makes reading your Facebook® or scrolling through Google® searches easier. Plus, tilting the wheel moves you backward or forward on the Web
Hyper-fast scrolling
Your spreadsheets and documents are getting longer. Your digital photo and music libraries are bursting at the seams. And you're glued to long Web pages that have you scrolling and scrolling and .... To get through it all, you're doing a whole lot of scrolling. We're talking 26 feet of it in your average eight-hour day, according to a Logitech study.
That's where hyper-fast scrolling comes in.
When you need to do some long-distance scrolling, hyper-fast scrolling unleashes the speed demon inside. What's going on under the hood? The ratchet-scrolling mechanism you're used to retracts so the wheel can spin with virtually no friction.
Seven seconds. That's how long some of our scroll wheels spin freely--speeding you through hundreds of pages or thousands of rows.
And, oh yeah, it's got precision handling too. With normal click-to-click scrolling, you can navigate your lists, slides, and images with the line-by-line control you need.
Comfortable contoured design
Based on the best-selling shape in the world, the contoured shape with textured rubber grips keeps your hand happy--even after long hours.
Up to 18-month battery life
The long battery life virtually eliminates the hassle of changing batteries. Smart sleep mode saves power, while an indicator light eliminates surprises
Logitech Unifying Nano-receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless device--without the hassle of multiple USB receivers.
Logitech Advanced 2.4 GHz wireless
You get the reliability of a cord with wireless convenience and freedom--fast data transmission and virtually no delays or dropouts.
Logitech Advanced Optical Tracking
From surfing the Web to navigating your Facebook with precision clicking, pointing and dragging, everything you do on your laptop is just easier thanks to our advanced tracking technology. And you don't need a mouse pad either.
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice at a price you can afford--plus a three-year limited hardware warranty
Perfect for laptops and netbooks
Your mouse works with Windows®, Mac® and Linux®. No matter what type of computer you own today--or buy tomorrow--you can depend on your mouse to work like you expect.
  • Micro-precise scrolling
    Designed for how you use the Web, our newest micro-precise scrolling makes reading your Facebook , shopping online or scrolling through Google searches easier. Plus, tilting the wheel moves you backward or forward on the Web
  • Comfortable contoured design
    Based on the best-selling shape in the world, the contoured shape with textured rubber grips keeps your hand happy-even after long hours. 1
  • Up to 18-month battery life
  • Connect with ease
    You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it
  • Logitech Advanced 2.4 GHz wireless
    You get the reliability of a cord with wireless convenience and freedom-fast data transmission and virtually no delays or dropouts
  • Logitech Advanced Optical Tracking
  • Logitech reliability
    You get the high quality and reliability that have made Logitech the global leader for mice at a price you can afford-plus a three-year limited hardware warranty
  • Perfect for laptops
    Your mouse works with Windows , Mac, Chrome OS and Linux . No matter what type of computer you own today-or buy tomorrow-you can depend on your mouse to work like you expect
  • Wheel for the Web
    Say good-bye to the tricky touchpad. Micro-precise scrolling makes everything you love to do online easier
  • A comfort to many
    Treat your hand to the comfy, contoured shape and soft rubber grips of the best-selling shape in the world
  • 18 months of fun
    With up to 18 months of battery life, it's so hassle free you might just forget it runs on batteries
Logitech M325 - Color Collection Limited Edition - mouse - 2.4 GHz - light grey
Mouse
Wireless - 2.4 GHz
Light grey
5.7 cm x 9.8 cm x 3.9 cm
88 g
Wireless Receiver
Movement Detection Technology
Optical
Buttons Qty
3
Tilt Wheel technology, on/off power switch, Logitech Unifying receiver
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
5.7 cm
9.8 cm
3.9 cm
88 g
Light grey
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
3
1 x USB - 4 pin USB Type A
AA type
Installed Qty
1
Run Time (Up To)
18 months
Limited warranty - 3 years
