Enjoy extra comfort for your right hand through curved grips made of soft rubber. Go longer between battery changes thanks to the energy efficient engineering. Plus, M280 automatically puts itself to sleep when you're not using it.
Get ultra precision and responsiveness with Logitech Advanced Optical Tracking. Plug it once and forget it. Nano receiver gives you a convenient and reliable wireless connectivity.
Crafted for your hand
Enjoy extra comfort for your right hand through curved grips made of soft rubber -
18-month battery life
Go longer between battery changes thanks to our energy efficient engineering. Plus, M280 automatically puts itself to sleep when you're not using it -
Smooth and precise tracking
Get ultra precision and responsiveness with Logitech Advanced Optical Tracking -
Plug-and-forget Nano receiver
- Logitech M280 - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right-handed
- 6.79 cm x 10.54 cm x 3.84 cm
- 91 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, auto sleep mode, Logitech Advanced Optical Tracking
- Battery
- AA type
- OS Required
- Linux Kernel 2.6 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Microsoft Windows Vista / 7 / 8
- Works With Chromebook
- 2-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Right-handed
- 6.79 cm
- 10.54 cm
- 3.84 cm
- 91 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Included Accessories
- 1 AA battery
- AA type
- Run Time (Up To)
- 18 months
- OS Required
- Limited warranty - 2 years
