Logitech Wireless Mouse M185 - wireless - 2.4 GHz - USB wireless receiver - blue
Quicklinx: 8HBPWS00 Mfr#: 910-002236
Recommended Use: Office, Mobile
Type: Mouse
Wired / Wireless: Wireless
Colour: Blue
Compatibility: Mac, PC
More than 50 in stock
£11.36 ex VAT
£13.63 inc VAT
Logitech Wireless Mouse M815 is a simple, reliable mouse with Plug and Play wireless. You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. You'll enjoy the high quality and reliability. The tiny nano receiver works right away without software and is small enough to leave in your USB port, so you won't lose it. And on top of that, this comfy, contoured mouse treats your hand right.
  • Plug-and-forget nano receiver
    It works with Window , Mac, Chrome OS or Linux -based computers. So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about lost receivers
  • 1-year battery life
    You can go for a year without battery hassles. The On/Off switch and smart sleep mode help conserve power. 1
  • Logitech reliability
    You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty
  • Logitech Advanced 2.4 GHz wireless connectivity
    You get the reliability of a cord with wireless convenience and freedom-fast data transmission and virtually no delays or dropouts
  • Plug-and-play simplicity
    No software, no hassles-you simply plug in the tiny nano receiver and start using your mouse right away
  • Comfy, contoured shape
    The contoured design feels good in either hand and offers more comfort than a touchpad
  • Perfect for laptops
    Your mouse works with Windows , Mac, Chrome OS and Linux . No matter what type of computer you own today-or buy tomorrow- you can depend on your mouse to work like you expect
  • Reliable wireless
    No delays or dropouts. The tiny wireless receiver gives you a connection you can count on
  • All-year power pack
    With 12 months of battery life, you don't have to deal with the hassle of frequent battery changes
  • Built to last
    You'll enjoy the high quality and reliability Logitech is known for-plus a 3-year limited hardware warranty
Logitech M185 - mouse - 2.4 GHz - blue
Mouse
Wireless - 2.4 GHz
Blue
Wireless Receiver
Movement Detection Technology
Optical
Nano wireless receiver
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Blue
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
Plug and Play
AA type
Installed Qty
1
Run Time (Up To)
1 year
Limited warranty - 3 years
Recommended Use: Mobile
Type: Mouse
Colour: Blue
Compatibility: Mac
Compatibility: PC
Brand: Logitech
Stock Status: In stock
