Logitech Wireless Mouse M815 is a simple, reliable mouse with Plug and Play wireless. You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. You'll enjoy the high quality and reliability. The tiny nano receiver works right away without software and is small enough to leave in your USB port, so you won't lose it. And on top of that, this comfy, contoured mouse treats your hand right.
Plug-and-forget nano receiver
It works with Window , Mac, Chrome OS or Linux -based computers. So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about lost receivers -
1-year battery life
You can go for a year without battery hassles. The On/Off switch and smart sleep mode help conserve power. 1 -
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty -
Logitech Advanced 2.4 GHz wireless connectivity
You get the reliability of a cord with wireless convenience and freedom-fast data transmission and virtually no delays or dropouts -
Plug-and-play simplicity
No software, no hassles-you simply plug in the tiny nano receiver and start using your mouse right away -
Comfy, contoured shape
The contoured design feels good in either hand and offers more comfort than a touchpad -
Perfect for laptops
Your mouse works with Windows , Mac, Chrome OS and Linux . No matter what type of computer you own today-or buy tomorrow- you can depend on your mouse to work like you expect -
Reliable wireless
No delays or dropouts. The tiny wireless receiver gives you a connection you can count on -
All-year power pack
With 12 months of battery life, you don't have to deal with the hassle of frequent battery changes -
Built to last
You'll enjoy the high quality and reliability Logitech is known for-plus a 3-year limited hardware warranty
- Logitech M185 - mouse - 2.4 GHz - blue
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Blue
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Nano wireless receiver
- Battery
- 1 x AA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- Blue
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- 1 x USB - 4 pin USB Type A
- Plug and Play
- AA type
- Installed Qty
- 1
- Run Time (Up To)
- 1 year
- OS Required
- Limited warranty - 3 years
