Logitech Wireless Keyboard K360 2.4GHz UK layout
Quicklinx: 7X93WS00 Mfr#: 920-003082
Recommended Use: Leisure, Mobile
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
32 in stock
£24.96 ex VAT
£29.95 inc VAT
The wireless keyboard that's beautifully convenient and conveniently compact thanks to its space-saving design with familiar layout, long battery life and instant access to the things you do most.
The perfect laptop companion - this compact keyboard lets you type with more comfort while taking up less space. The long battery life is so hassle-free you just might forget it uses batteries at all. You can do more, faster with six hot keys and twelve programmable F-keys for instant access to music, email and more.
  • Compact comfort for your laptop
    You can type in more comfort with a layout you're used to. And it's about 20% smaller than our standard keyboards, so it fits in your office, your living room or wherever you use your laptop
  • Three-year battery life
    The extended battery life means you won't spend your time tracking down new batteries. 1
  • Six hot keys
    Skip a song. Pause a video. Turn up the volume. You get six hot keys for instant access to play, pause, previous, next, volume and mute
  • Twelve programmable F-keys
    You're in charge with programmable F-keys you can easily customize to open your favorite applications, folders or Web pages. 2
  • Advanced 2.4 GHz wireless
    So you can work or play in more places-like your comfy couch-the long-range wireless connection virtually eliminates delays, dropouts and interference
  • Logitech Unifying receiver
    The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse, keyboard or number pad-without the hassle of multiple USB receivers
  • Plug-and-play simplicity
    Setup takes seconds-you simply plug the wireless receiver into a USB port, pull the battery tab and start using your keyboard right away without software
  • Whisper-quiet, framed keys
    The framed keys look modern and barely make a sound, while providing a more comfortable typing experience than laptop and netbook keyboards
  • Sturdy, adjustable-tilt legs
    You can extend the sturdy folding legs to increase the keyboard tilt by eight degrees to address your personal comfort needs. Rubber feet prevent slipping
  • Compact comfort
    The perfect laptop companion-this compact keyboard lets you type with more comfort while taking up less space
  • Power-packed
    The three-year battery life is so hassle-free you just might forget it uses batteries at all
  • Just one touch
    You can do more, faster with six hot keys and twelve programmable F-keys for instant access to music, e-mail and more
  • More power
    You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it. Learn more about the Logitech Unifying receiver
Logitech Wireless Keyboard K360 - keyboard - English
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
English
Hot Keys Qty
18
38.1 cm x 15.6 cm x 1.9 cm
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Input Device
Wireless
Hot Keys Qty
18
English
38.1 cm
15.6 cm
1.9 cm
Plug and Play
Microsoft Windows Vista / XP / 7
AA type
Installed Qty
2
Limited warranty - 3 years
Recommended Use: Mobile
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 0 - 50
