Logitech Wireless Headset H800
Quicklinx: 7WY4WS00 Mfr#: 981-000338
Recommended Use: Computer
Connectivity: Wireless
Earcover : Binaural
More than 50 in stock
£77.20 ex VAT
£92.64 inc VAT
This comfortable, wireless headset lets you chat, rock and surf on multiple devices like your PC, tablet and smartphone - with rich digital stereo and a full set of on-ear controls.
  • WIRELESS AUDIO
    Pair any Bluetooth -enabled device or insert the leave-in nano receiver into a USB port and move freely away from your connected devices up to 12m away. Rechargeable battery provides six hours of reliable wireless audio
  • RICH HIGH-DEFINITION STEREO SOUND
    Laser-tuned drivers and built-in equalizer keep distortion to a minimum. Enjoy rich, crystal-clear, digital audio that lets you detect even the most subtle noises for full immersion in music, games and calls
  • NOISE CANCELING MIC
    Flexible mic can be positioned for better voice capture and background noise reduction. Right-sided boom can be tucked inside the headband and out of the way when you're not using it
  • ON-EAR CONTROLS
    Full set of controls including volume, mute, call handling, song advance/replay, and device select located on the right ear cup. Adjust ongoing calls and entertainment without disruption. Store the nano-receiver inside the left ear cup when you're on-the-go
  • CUSHIONED COMFORT
    Padded headband and sculpted foam ear cups provide hours of comfort. Headset folds up easily for portability
  • USB RECEIVER + BLUETOOTH
    Simply insert the USB nano-receiver into your computer USB port or pair your Bluetooth -enabled smartphone, computer or tablet. Charge via the included USB cable; even talk while it's charging. Enjoy up to six hours of wireless audio for all your calls, music or games
Logitech Wireless Headset H800 - headset
Headset - 2.4 GHz - wireless
Recommended Use
Computer
Headphones Form Factor
On-ear
Wireless
Wireless Technology
2.4 GHz radio frequency
Radio Frequency Range
2.4GHz
Sound Output Mode
Stereo
Microphone
Boom
Recommended Use
Computer
Max Operating Distance
12 m
Audio Output
On-ear
Wireless
Wireless Technology
Sound Output Mode
Stereo
Microphone
Boom
Wireless Link
2.4GHz
Transmission Range
12 m
Connector Type
USB (4 PIN USB Type A)
Wireless adapter
Cable Details
USB charge cable
Headphone battery
Run Time (Up To)
6 hour(s)
Earcover : Binaural
Brand: Logitech
Price Range Ex VAT: 50 - 100
