This comfortable, wireless headset lets you chat, rock and surf on multiple devices like your PC, tablet and smartphone - with rich digital stereo and a full set of on-ear controls.
WIRELESS AUDIO
Pair any Bluetooth -enabled device or insert the leave-in nano receiver into a USB port and move freely away from your connected devices up to 12m away. Rechargeable battery provides six hours of reliable wireless audio -
RICH HIGH-DEFINITION STEREO SOUND
Laser-tuned drivers and built-in equalizer keep distortion to a minimum. Enjoy rich, crystal-clear, digital audio that lets you detect even the most subtle noises for full immersion in music, games and calls -
NOISE CANCELING MIC
Flexible mic can be positioned for better voice capture and background noise reduction. Right-sided boom can be tucked inside the headband and out of the way when you're not using it -
ON-EAR CONTROLS
Full set of controls including volume, mute, call handling, song advance/replay, and device select located on the right ear cup. Adjust ongoing calls and entertainment without disruption. Store the nano-receiver inside the left ear cup when you're on-the-go -
CUSHIONED COMFORT
Padded headband and sculpted foam ear cups provide hours of comfort. Headset folds up easily for portability -
USB RECEIVER + BLUETOOTH
Simply insert the USB nano-receiver into your computer USB port or pair your Bluetooth -enabled smartphone, computer or tablet. Charge via the included USB cable; even talk while it's charging. Enjoy up to six hours of wireless audio for all your calls, music or games
- Logitech Wireless Headset H800 - headset
- Product Type
- Headset - 2.4 GHz - wireless
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless
- Wireless Technology
- 2.4 GHz radio frequency
- Radio Frequency Range
- 2.4GHz
- Sound Output Mode
- Stereo
- Microphone
- Boom
- 2-year warranty
- Product Type
- Recommended Use
- Computer
- Max Operating Distance
- 12 m
Headphones
- On-ear
- Wireless
- Sound Output Mode
- Stereo
Microphone
- Boom
Wireless Link
- 2.4GHz
- Transmission Range
- 12 m
- Connector Type
- USB (4 PIN USB Type A)
- Cables Included
- USB charge cable
- Included Accessories
- Wireless adapter
- Battery
- Headphone battery
- Run Time (Up To)
- 6 hour(s)
- Limited warranty - 2 years
