The combo that puts entertainment and portability at your fingertips--thanks to 11 hot keys and a go-anywhere mouse.
Multimedia hot keys
Skip a song. Pause a video. Turn up the volume. You get 11 multimedia hot keys for instant access to play, pause, previous, next, volume and mute.
Sleek, comfortable design
The keyboard's sleek design and low-profile, whisper-quiet keys make for a more comfortable typing experience than laptop and netbook keyboards.
Portable wireless mouse
You can take the sleek mouse anywhere you take your computer. Plus, the included storage compartment makes it easy to store the nano-receiver.
Extended battery life
A 24-month keyboard and 12-month mouse battery life mean you can go for months without the hassle of changing batteries.
Advanced 2.4 GHz wireless
So you can work or play in more places--like your comfy couch--the long-range wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10 meters
Plug-and-play simplicity
Setup couldn't be easier--you simply plug the wireless receiver into a USB port on your computer and you'll be exploring MSN, shopping online and searching Google right away without software.
12 programmable F-keys
You're in charge with programmable F-keys that you can easily customize to open your favorite applications, folders or web pages.
*Logitech Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse, keyboard or number pad--without the hassle of multiple USB receivers
Sleek design
The full-size keyboard's low-profile, whisper-quiet keys make typing efficient and comfortable. The mouse's gentle curve makes it comfortable for all-day use -
Setup couldn't be easier, so you can get right to business -
Up to 2 years for the keyboard and 1 year for the mouse to minimize recharging hassle -
Eleven multimedia hot keys; 4 programmable F-keys
Enables instant access to multimedia options, the Internet, e-mail, play/pause, volume and more for meetings and conferences; allows you to re-program the F-keys to open your favorite applications, folders or webpages
- Logitech Wireless Combo MK330 - keyboard and mouse set - English - United Kingdom - black
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Input Device
- Keyboard - wireless
- Layout
- Hot Keys Qty
- 17
- Hot Keys Function
- Sleep, application switching, My Computer, e-mail, volume, search, mute, Show Desktop, lock computer, play/pause, previous track, next track, media player
- On/off power switch
- Pointing Device
- Mouse - optical
- Buttons Qty
- 3
- On/off power switch, 1000 dpi resolution
- Black
- 3 years warranty
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 42.5 cm x 18 cm x 2.2 cm / 570 g , Mouse: 5.9 cm x 10 cm x 3.75 cm / 76 g
Input Device
- Keyboard Name
- Logitech Wireless Keyboard K330
- Hot Keys Qty
- 17
- Hot Keys Function
- Layout
Pointing Device
- Mouse
- Pointing Device Name
- Logitech Wireless Mouse M215
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Pointing Device Features
- Black
- Included Accessories
- USB extender
- Plug and Play
- OS Required
- Microsoft Windows Vista / XP / 7
- AA / AAA
- Installed Qty
- 3
- Required Qty
- 3
- Technology
- Alkaline
- Limited warranty - 3 years
