Logitech USB HEADSET H390
Stereo Headset H390
Quicklinx: 7NFLWS00 Mfr#: 981-000406
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
£28.29 ex VAT
£33.94 inc VAT
A versatile headset lets you get comfortable with digital sound. You'll be comfortable with this headset thanks to the plush ear pads and padded headband that adjusts to you. You've got it easy - this plug-and-play USB headset gives you quick access to volume and mute controls.
  • Comfortable design
    The adjustable, padded headband and plush ear pads keep you comfortable
  • Noise-canceling microphone
    You won't have to compete with background noise to be heard
  • Rotating microphone
    The microphone rotates out of the way when you're listening to music or watching a movie
  • In-line audio controls
    You can instantly adjust the volume and mute the microphone
  • Pure digital USB
    You'll experience clear, digital sound with the simplicity of a single USB plug-and-play connection.What's good about USB for headsets?
  • Feeling good
  • Loud and clear
    The noise-canceling microphone cuts background noise-and rotates out of the way when you're not using it
  • Easy listening
    You've got it easy-this plug-and-play USB headset gives you quick access to volume and mute controls
Logitech USB Headset H390 - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity -62 dBV/uBar
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Mute, volume
Headset - wired
Recommended Use
Computer
Headphones
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
-62 dBV/uBar
In-Cord Volume Control
Microphone
Boom
Mono
Sensitivity
-42 dBV/Pascal
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Mute, volume
Connector Type
USB
Cable Details
Headset cable - 2.4 m
Connectivity: Wired
Earcover : Binaural
Brand: Logitech
Price Range Ex VAT: 0 - 50
