Logitech USB Headset H340 Black
Quicklinx: 8Y40WS00 Mfr#: 981-000475
Recommended Use: Computer
Connectivity: Wired
Earcover : Binaural
More than 50 In Stock
£25.67 ex VAT
£30.80 inc VAT
With crystal-clear digital sound, your Internet calls, music, viral videos, and more will sound better than they ever have. Enjoy a perfect, comfortable fit - with an adjustable, lightweight design.
  • DIGITAL STEREO SOUND
    Enjoy crystal clear audio for music, games and calls. This plug-and-play headset can be used with any PC or Mac computer without the need to install software
  • NOISE CANCELING MIC
    Right-sided mic can be positioned for better voice capture and background noise reduction. Discreet boom can be tucked inside the headband and out of the way when you're not using it
  • ADJUSTABLE HEADBAND
    Lightweight headband with swivel-mounted foam ear cushions provide hours of audio comfort
  • USB CONNECTION
    USB provides easy plug-and-play operation. Simply plug the USB connector into your computer and you're ready to talk, listen to music or play games
Logitech USB Headset H340 - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear binaural
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Microphone Operation Mode
Mono
Headset - wired
Recommended Use
Computer
Audio Output
On-ear binaural
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Microphone
Boom
Mono
Sensitivity
-40 dBV/Pascal
Frequency Response
100 - 10000 Hz
Connector Type
USB (4 PIN USB Type A)
Cable Details
USB cable - 1.8 m
Connectivity: Wired
Earcover : Binaural
Brand: Logitech
