Made with a brushed metallic body and a silky-smooth touch surface, this mouse perfectly complements the sleek good looks of your ultrabook computer. Super thin and feather light, T630 slips nearly invisibly into a computer sleeve or even the pocket of your skinniest jeans. Your favorite mouse can go everywhere you do.
An ultra-portable pair
Super thin and feather light, T630 slips nearly invisibly into a computer sleeve or even the pocket of your skinniest jeans. Your favorite mouse can go everywhere you do -
Touch your way around
Experience Windows 8 navigation-effortlessly and confidently. T630 simplifies the touch experience with natural, intuitive gestures and makes you look good-and feel good-doing it -
One mouse, multiple devices
T630 connects to your devices using Bluetooth wireless technology. And our Easy-Switch technology makes it simple to toggle between your Ultrabook or desktop with the flip of a switch -
Perfectly sized for a fingertip grip
At just over 8 cm long and 5 cm wide , T630 relies on only your fingertips to operate. The precision sensor responds to even the slightest movements, and the touch surface registers nine different touch gestures -
Quick charge
Just one minute of charge time gives you enough power to keep working for another hour. If the charge runs low, simply plug it in. Your mouse charges over USB, so it's ready when you are
- Logitech Ultrathin Touch Mouse T630 - mouse - Bluetooth
- Mouse
- Connectivity Technology
- Wireless - Bluetooth
- Cables Included
- USB charge cable
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.6.8 or later, Windows 8
- 3-year warranty
- Mouse
Input Device
- Wireless
- Interface
- Bluetooth
- 1 x USB - 4 pin USB Type A
- Cables Included
- USB charge cable
- OS Required
- Limited warranty - 3 years
