UE BOOM 2 pleads insanity. And it's guilty. It's the 360-degree wireless speaker that blasts loud, insanely great sound with deep, powerful bass in every direction - everywhere you go.
Sound for any adventure
Rain or shine, rage, riot, party and bring the beats to your favorite beaches, trails, caves and climbs. -
Go anywhere
UE BOOM 2 is waterproof, dirt-proof, shockproof and crafted from the extremely sexy and uninhibited premium materials. -
Waterproof
Life is messy - drinks get spilled, things get thrown in pools, and rain turns fields into mud pits. UE BOOM 2 was made for those moments. Get wet and dirty and make some memories. -
Designed for everywhere
Take the music as far as you can go. Strap it to your board. Put it on your bike. Grab some friends and party onward into the unknown. -
Wireless range
Control the party from the distance. Connect from phones, tablets and your other Bluetooth enabled devices. And when you get hungry, use the speakerphone to order some pizza and drinks. -
Long-hour battery life
UE BOOM 2 has a rechargeable battery that gives you long hours of non-stop music.
- Ultimate Ears BOOM 2 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use
- Protection
- Waterproof
- Speaker Type
- Active
- Frequency Response
- 90 - 20000 Hz
- Amplifier
- Integrated
- Bluetooth, NFC
- Intelligent Assistant
- Siri, Google Now, Alexa - indirect
- Phantom
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 18 cm
- Dimensions - Diameter
- 6.7 cm
- 548 g
- 2-year warranty
- Product Type
- Hands-Free Function
- Protection
- Waterproof
- Enclosure Colour
- Phantom
Speaker System
- Speaker Type
- Active
- 90 - 20000 Hz
- Max Output Level (Max SPL)
- 90 dBA
- Amplifier
- Integrated
- Bluetooth, Near Field Communication (NFC)
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Transmission Range
- 33 m
- Controls
- Volume
Internet of Things (IoT)
- Communications Technology
- Bluetooth
- Voice Control
- Indirect
Speaker System Details
- Driver Details
- Speaker: 2 x full-range driver - 1.75" , Speaker: 2 x Passive Radiator - 1.75" x 3"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 15 hour(s)
- Diameter
- 6.7 cm
- 18 cm
- 548 g
- Limited warranty - 2 years
