Logitech TAP IP - Graphite
Quicklinx: HCCPWS00 Mfr#: 952-000085
28 In Stock
£543.68 ex VAT
£652.41 inc VAT
Deploy video meeting rooms at scale with Logitech Tap IP, a touch controller that delivers the simplicity of one-touch join and a consistent experience across all video conferencing rooms.
With a single PoE cable and available Table, Riser, Wall mounts, Tap IP can be conveniently installed anywhere in the room. Prevent the controller from being unplugged thanks to clean cable management, and be confident that each room stays ready for the next video meeting.
Tap is sold as a standalone device for custom deployments or as part of Logitech room solutions bundles for Microsoft Teams, Zoom Rooms, and other video conferencing services.
  • Just the Right Presence
    With a spacious 10.1" display, low profile, and motion sensor for always-on readiness, Tap IP has a sleek and unobtrusive presence in the room
  • Simple and Secure Cabling
    Streamline setup with a single cable that can be routed through the back or below the device. Keep connections tight with built-in strain relief and retention mechanisms
  • Multiple Mounting Options
    Install Tap IP almost anywhere in the room with Table and Riser Mounts that fit standard table grommets and rotate 180° for visibility and convenience. Or save table space in small rooms with the Wall Mount
  • Clean Installations
    With a single Power over Ethernet cable, place Tap IP conveniently near room participants for a tidy and professional install
  • Logitech Select
    AN ALL-IN-ONE SERVICE PLAN Logitech Select is a comprehensive service plan that delivers reliability, continuity, and peace of mind for each room you designate. Select provides 24/7 support, a dedicated Customer Success Manager, Available with purchase of a service plan with 50 or more rooms. accelerated RMA, onsite spares, Available with purchase of a service plan with 50 or more rooms. and advanced Sync analytics including customizable alerts through ServiceNow integration. Available for users of Logitech Sync. LEARN MORE ABOUT LOGITECH SELECT>
  • Extended Warranty
    UP TO FIVE YEAR WARRANTY Purchasing an extended warranty Terms and conditions apply. Not available in all countries. Contact your reseller.  offers security and peace of mind that comes with knowing your Logitech video collaboration room systems and devices are protected against defects for up to five years from the purchase date. Extended warranties are available for either one year or three years beyond the original Logitech manufacturer's two-year warranty. LEARN MORE ABOUT EXTENDED WARRANTY> Not available in all countries. Contact your reseller
  • TABLE MOUNT
    Secures Tap IP to a table grommet while maintaining a low profile. Swivels 180° for convenient operation from both sides of the table. LEARN MORE ABOUT TABLE MOUNT>
  • RISER MOUNT
    Secures Tap IP to a table grommet and raises the viewing angle from 14° to 30° for better visibility from across the room. Swivels 180° for convenient operation from both sides of the table. LEARN MORE ABOUT RISER MOUNT>
  • WALL MOUNT
    Conserves table space by mounting Tap IP flush to the wall with a sturdy plate and cleat design. LEARN MORE ABOUT WALL MOUNT>
Logitech Tap IP - video conferencing device
Video conferencing device
24.62 cm x 17.13 cm x 5.61 cm
Display
10.1" IPS / 1280 x 800
IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet, Fast Ethernet, Bluetooth 5.0
24.62 cm
17.13 cm
5.61 cm
Built-in Devices
PIR sensor, accelerometer
Enclosure Colour
Graphite
Display
IPS
Diagonal Size
10.1"
Native Resolution
1280 x 800
Image Brightness
400 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
85° viewing angle, LED-backlit, 10-point multi-touch, anti-fingerprint, ambient lighting, 100 x 100 VESA mounting, touch screen
Wired, wireless
ARM TrustZone, security slot (Kensington security lock compatible)
IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 5.0
1 x network - Ethernet 10Base-T/100Base-TX (PoE) - RJ-45
Mounting hardware, table mount, wall mount
IEEE 802.3af, VESA FDMI, AES-128
10 - 95%
Brand: Logitech
Price Range Ex VAT: £500 - £750
