Your basket is empty
Logitech Spotlight Plus Presentation Remote Control
Quicklinx: CS6BWS00 Mfr#: 910-005166
Accessory Type: Remote Control
More than 50 in stock
£83.33 ex VAT
£99.99 inc VAT
Key Features:
- Brushed aluminium build
- Three-button remote
- Companion Windows and Mac software
- Haptic feedback
- USB-C charging
- Up to 3-months battery life
- Bluetooth with 30m wireless range
The Logitech Spotlight Presentation Remote gives you a new level of control over your presentations. Just install the Logitech Presentation app (available from Logitech) and then use the remote to manage your time, set vibration alerts, toggle pointer mode and customise actions within a user-friendly interface.
With Spotlight you can take a giant step beyond traditional laser pointing. This advanced system lets you precisely highlight or magnify areas of focus in pixel-perfect detail. It's clearly visible to both the audience in the room and everyone watching via video conference.
Small Device. Big Game.
Spotlight and its companion app work together to deliver a deep range of intelligent and customizable features. You'll step confidently onto stage, and right into your zone.
Intuitive Slide Navigation
Enjoy focus and instant familiarity with Spotlight's intuitive three-button interface.
- Pointer - Highlight, magnify, and control the on-screen cursor
- Next - Navigate forward, and control custom functions like gesture scrolling
- Back - Navigate backward, and control custom functions like gesture scrolling
Long Operating Range
Move and present freely from as far as 30 meters (100ft).
Universal Compatibility
Use Spotlight on Windows® and Mac platforms, and on Powerpoint®, Keynote®, PDF™, Google™ Slide and Prezi™ presentations.
Dual Connectivity
Plug-and-play Spotlight instantly on any compatible computer via USB receiver, or connect with low energy Bluetooth® Smart. Spotlight also keeps your computer connected and awake while you present.
Logitech Spotlight Plus - presentation remote control
Presentation remote control
Enclosure Colour
Slate
2.81 cm x 1.21 cm x 13.13 cm
49.2 g
Supported Devices
Notebook, personal computer
Wireless Technology
Bluetooth, 2.4 GHz
Buttons Qty
3 buttons
Max Operating Distance
30 m
Rechargeable - lithium polymer
3 years warranty
2.81 cm
1.21 cm
13.13 cm
49.2 g
Enclosure Colour
Slate
Wireless Technology
Bluetooth, 2.4 GHz
Supported Devices
Buttons Qty
3 buttons
30 m
Gyroscopic motion-sensing technology, power on/off
Connector Type
1 x USB
Operating System
MS Windows 7 or later, Apple Mac OS X 10.10 or later
Carrying pouch, USB wireless receiver, mini-USB charging cable
85 mAh
Run Time (Up To)
3 months
Recharge Time
1 hour
Limited warranty - 3 years
Brand: Logitech
Price Range Ex VAT: 50 - 100
