Logitech SmartDock is an AV control console that optimizes videoconferencing collaboration. Simply walk into a conference room and start your meeting with one-touch join.
- Logitech SmartDock - video conferencing kit
- Video conferencing kit
- 33.4 cm x 20.9 cm x 23.9 cm
- 2.738 kg
- Input Device
- Motion sensor (wired)
- Networking
- Power
- AC 120/230 V
- 2-year warranty
- 33.4 cm
- 20.9 cm
- 23.9 cm
- 2.738 kg
- Built-in Devices
- Docking station
Input Device
- Motion sensor
- Connectivity Technology
- Wired
- Data Link Protocol
- 3 x USB 3.1 - 9 pin USB Type A , 1 x network - Ethernet 1000Base-T - RJ-45 , 3 x audio / video - HDMI , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 - Microsoft Surface connector
- Cables Included
- HDMI cable - 3 m , Network cable - 3 m
- UL, FCC
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CQFL 041640 Condition: Customer return - item has been opened but is in excellent condition |
£55.32 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
