Turn your iPad Pro into a laptop with one click! Enjoy laptop-like typing anywhere, day or night, with Slim Folio Pro for iPad Pro. Three distinct use modes ensure you can always work at your highest level no matter where you are - a café table, desk, or even your lap.
The light and durable all-in-one case also keeps your device protected from bumps, scratches, and spills. It even features a convenient spot to charge and stow your Apple Pencil (2nd gen).
THREE USE MODES
Slim Folio Pro offers three unique modes to help you accomplish any task more efficiently. Type Mode: Just dock the keyboard upright and type away. Sketch Mode: Collapse the iPad screen to take notes or draw with Apple Pencil (2nd gen). Read Mode: Fold the keyboard back to read books, articles, and more -
PRO ANYWHERE, DAY OR NIGHT
Enjoy using your iPad at night or in dim lighting? We do, too. That's why the integrated keyboard comes equipped with backlit keys. Three adjustable levels of brightness ensure you can see what you're doing whether you're in the bedroom, on a plane, or any other low light environment -
OVER 20 YEARS OF TYPING INNOVATION
Decades of Logitech expertise have gone into ensuring that every keystroke is fluid, natural, and accurate. Enjoy hours of comfortable typing thanks to large, well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Our premium keyboards are designed with a scissor mechanism beneath each key to deliver the perfect bounce every time for fast, accurate typing -
HELPFUL iOS SHORTCUTS
Forget hunting around the screen or in menus to perform simple actions - Slim Folio Pro features a full row of shortcut keys. 1) Home: go to home screen 2) Key brightness: adjusts brightness of backlit keys, up or down 3) Search: brings up iOS search field 4) Virtual Keyboard: shows/hides the virtual keyboard 5) Media controls: Back, Play/Pause, Forward 6) Volume controls: Mute, Volume up, Volume down 7) Screen on/off: locks iPad Pro screen 8) Bluetooth Low Energy connect: pairs devices 9) Battery Check: LED light shows battery status -
FRONT AND BACK PRO PROTECTION
Keep the front and back of your iPad safe from scuffs, scratches, and spills. Slim Folio Pro securely holds iPad Pro in a lightweight case that keeps corners protected and doesn't weigh you down. Outer fabric is smooth and soft to the touch -
CONVENIENT MAGNETIC LATCH
A secure magnetic latch keeps the case securely closed when not in use to protect your iPad screen. The latch also features a convenient storage loop for Apple Pencil (2nd gen) and other digital pencils -
DESIGNED FOR Apple Pencil (2ND GEN)
The Slim Folio Pro case is designed with open sides so you can charge Apple Pencil (2nd gen) with the case on. When you're done drawing, slip Apple Pencil into the magnetic latch to prevent it from being knocked loose during travel -
START TYPING INSTANTLY
With a built in auto on/off feature, simply place iPad in type mode to turn the keyboard on. Then remove iPad Pro from the dock to put the keys to sleep. This conserves power so you're able to type longer between charges -
PRO ON AND ON AND ON…
Slim Folio Pro is powered by an impressively long-lasting battery that can go 3 months on a single charge. Just use the USB-C cable included with your iPad Pro and charge via a power brick or by connecting directly to your iPad Pro -
PAIR ONCE AND YOU'RE DONE
Slim Folio Pro uses advanced Bluetooth Low Energy wireless connection for reliable, energy-efficient connection between iPad Pro and keyboard. Simply set up your connection once, and your keyboard will automatically connect every time you place your iPad Pro into type mode -
2-YEAR WARRANTY
If you need help with a product, our Customer Care team is happy to help. Learn more about our product warranties
- Logitech Slim Folio Pro - keyboard and folio case - QWERTY - UK Input Device
- Keyboard and folio case
- Backlit
- 3-level
- Interface
- Bluetooth
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia, volume, search, brightness, screen lock, home screen, battery check button
- Protection
- Scratch-resistant, spill-resistant
- 28.7 cm x 23 cm x 2.246 cm
- 707.43 g
- 2-year warranty
- Designed For
- Apple 12.9-inch iPad Pro (3rd generation)
- Backlit
- 3-level
- Interface
- Bluetooth
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Scissors
- Protection
- 28.7 cm
- 23 cm
- 2.246 cm
- 707.43 g
Carrying Case
- Magnetic closure, camera lens cutout, transformable into a stand for typing or viewing video, stylus holder, port cut-outs, sleep/wake function, AutoSleep, protective corners
- Rechargeable
- Limited warranty - 2 years
- Designed For
