Logitech Slim Folio Keyboard and Folio Case Bluetooth UK
Quicklinx: CXR7WS00 Mfr#: 920-008624
Slim Folio takes mobile computing to a higher level. Now you can enjoy laptop-like typing anywhere you take your tablet. Its slim, light design makes it a joy to use and carry around, all the while keeping your device safe from bumps, scratches and spills. No matter where you need to get your work done - a café table, a desk or even your lap - Slim Folio locks your tablet at an optimal angle for typing and holds firm on any surface.
  • NOW YOUR IPAD CAN ACT LIKE A LAPTOP
    Enjoy hours of comfortable, flexible typing thanks to large well-spaced keys stretched edge-to-edge so your hands won't feel crowded. Mechanical scissor keys are tuned for productivity with 1.5 mm key travel - an optimal depth for comfortable and responsive typing. A full row of iOS shortcut keys put iPad controls at your fingertips - change volume, language and more - all without leaving the keyboard
  • TYPE ON YOUR DESK OR YOUR BLUE JEANS
    Simply open the case and start typing. Your iPad is locked in the perfect typing position and stays firmly in place even when typing on uneven surfaces like your lap
  • TYPING AND VIEWING MODES
    Two different angles make the most of the beautiful iPad screen whether you're writing your travel blog, watching videos, playing games or reading a novel
  • FRONT AND BACK PROTECTION
    SLIM FOLIO carefully envelopes your iPad for all-around protection against bumps, scratches and spills. Outer technical fabric is soft to touch, yet resistant to wear and tear and spills. On the inside, a lightweight frame and keyboard module provide structural integrity without weighing down your iPad
  • FOUR YEAR BATTERY LIFE
    Ready when you need it, SLIM FOLIO uses replaceable coin cell battery to power your keyboard. Thanks to a smart power management system, it lasts up to 4 years without a need to replace it. Its auto on-off function turns your iPad on every time you open the folio and puts it back to sleep when you close it, helping you save precious battery life without even having to think about it
  • EASY SETUP, RELIABLE CONNECTION
    Advanced Bluetooth LE provides a reliable connection that won't drop between tablet and keyboard. Setup is easy - three simple steps take about a minute to complete
Logitech Slim Folio - keyboard and folio case - QWERTY - UK - black Input Device
Keyboard and folio case
Bluetooth
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, iPad functions
Protection
Scratch-resistant, spill-resistant
24.8 cm x 18.2 cm x 2 cm
700 g
Bluetooth
Hot Keys Function
QWERTY UK
Keyboard Technology
Scissors
Protection
24.8 cm
18.2 cm
2 cm
700 g
Carrying Case
Magnetic closure, AutoSleep
Installed Qty
2
Required Qty
2
