Logitech Slim Combo Keyboard and Folio Case for iPad (5th Gen & 6th Gen)
Quicklinx: DXQ6WS00 Mfr#: 920-009047
Wired / Wireless: Wireless
Colour: Black
Compatibility: Apple iOS
More than 50 in stock
£77.59 ex VAT
£93.10 inc VAT
Slim Combo pairs with your tablet for a great experience. Four distinct modes give you amazing versatility, and the smart connector pairs and powers your keyboard in one magical instant.
  • FOUR VERSATILE MODES
    SLIM COMBO supports everything you do with your iPad with 4 versatile modes: Type Mode: Click the keyboard into the upright position and type away. View Mode: Set the keyboard aside and use SLIM COMBO in the the hands-free View Mode - perfect for watching videos and more. Studio Mode: Push the screen all the way down into Studio Mode. Comfortably draw and take notes with a digital pencil. Book Mode: Fold the kickstand back into the hand-held Book Mode - perfect for reading
  • LAPTOP-LIKE TYPING ALL DAY AND NIGHT
    A laptop-like layout with well-spaced keys gives you hours of comfortable, precise typing. The backlit keys, with 3 levels of adjustable backlighting, let you type anytime - day or night. A full row of iOS shortcut keys gives you access to iPad controls, right at your fingertips - control media, volume, screen brightness, and more
  • TYPE WITH KEYBOARD ATTACHED OR DETACHED
    With SLIM COMBO's detachable keyboard, you have all sorts of options. Type with the keyboard attached or detached - whatever feels right for what you're doing
  • FLEXIBLE VIEWING ANGLES
    See everything clearly at any angle. With 40 degrees of adjustable viewing angles and an adjustable kickstand, SLIM COMBO smoothly reclines and stays in place. No matter where you are - on the sofa, at a desk or on an airplane, get a perfect view of your gorgeous iPad screen
  • DURABLE PROTECTION
    Keep your iPad in tip-top shape. SLIM COMBO carefully encases your iPad for all-around protection against bumps, scratches, and spills. Outer materials are durable, built to withstand daily wear and tear, and makes SLIM COMBO perfect for slipping in and out of bags
  • HOME FOR APPLE PENCIL
    Sketch, write, then store your Apple Pencil where it won't get lost or in the way. The convenient holder will keep it firmly in place until you're ready to use it next
  • RELIABLE BLUETOOTH CONNECTION
    Simply set up your connection one time and your keyboard will automatically connect every time you put your iPad into Type Mode. SLIM COMBO uses advanced Bluetooth LE wireless for reliable, energy-efficient connection that won't drop between the iPad and keyboard
  • LONG-LASTING BATTERY LIFE
    Keep working, watching, or playing without having to worry about short battery life. Thanks to a smart-power management system, the rechargeable battery lasts up to 3 months on a single charge
  • 2 YEAR WARRANTY
    We stand behind our products and commitment to excellence. If you need help with a product, our Customer Care team is happy to help. Learn more about our product warranties.
Logitech Slim Combo - keyboard and folio case - QWERTY - UK - black
Keyboard and folio case
Backlit
Bluetooth
Input Device
Keyboard
Localization and Layout
QWERTY UK
Hot Keys Function
Search, mute, play/pause, previous track, next track, home screen, Siri, volume -, volume +, language key
Protection
Scratch-resistant, spill-resistant
Black keyboard, black case
Case Material
Plastic, fabric
17.766 cm x 2.456 cm x 24.62 cm
490 g
Apple 9.7-inch iPad (5th generation, 6th generation)
Backlit
Bluetooth
Input Device
Keyboard
Hot Keys Function
QWERTY UK
Keyboard Technology
Scissors
Protection
17.766 cm
2.456 cm
24.62 cm
490 g
Carrying Case
Material
Plastic, fabric
Pen holder, adjustable viewing angles, water repellent
Rechargeable
Colour: Black
Brand: Logitech
Price Range Ex VAT: 50 - 100
