Logitech Rally Plus Video Conferencing Kit
Quicklinx: F7KNWS00 Mfr#: 960-001242
25 in stock
£1,968.60 ex VAT
£2,362.32 inc VAT
Logitech Rally sets a new standard for USB-connected conference camera systems, uniting premium design and materials with unmatched audio and video performance.
  • See Everyone, Perfectly Framed
    Logitech RightSight camera control 1 automatically moves and adjusts the lens to comfortably frame meeting participants in rooms of all shapes and sizes. Coming soon for Windows 10 and macOS
  • Let the Sunshine In
    Even in meeting rooms with bright windows, Logitech RightLight technology with Wide Dynamic Range (WDR) prioritizes faces and human figures over objects and surfaces. The result is a balanced image that renders participants in flattering light with reduced glare and softer shadows, even in dim or backlit conditions
  • Adaptive Pan, Tilt and Zoom
    Pan and tilt speeds automatically adapt to the level of zoom. The result: faster camera movement when zoomed out for quick framing and slower camera movement when zoomed in for more control
  • Front of Room Audio
    Unlike tabletop speakerphones that decouple voices from video, Rally speakers are designed for placement at the front of the room. By aligning speakers with the display, a person' s voice and video both come from the same place and never from behind you- so conversations feel more natural and lifelike
  • Optional Mounting Kit
    Add Rally Mounting Kit for a streamlined installation of each component. Strong wall mounts allow ideal placement for the camera and two speakers, while ventilated mounting plates attach the display and table hubs on a wall or beneath a table. Two cleverly-designed retainers keep cables secure
  • Loud and Clear
    The Rally display hub powers up to two speakers, providing rich sound even in larger rooms. A patent-pending suspension system virtually eliminates vibrations that travel through walls, stands, and tables. This improves echo cancellation while keeping video shake-free, even at high volume levels and when zoomed in
  • Up to 7 Mic Pods
    For rooms with more than 10 participants, add Rally Mic Pods to expand audio coverage and provide convenient access to mute controls. Each pod adds coverage for six more participants, so you can deploy Rally in large meeting spaces and boardrooms with up to 46 people
  • Flexible Mic Pod Cabling
    A more flexible alternative to daisy-chain connections, Rally Mic Pod Hub makes it easy to run cables beneath the table with three connections for Rally Mic Pods or additional Mic Pod Hubs. With a single-cable connection, participants can reposition individual mic pods to make space on the table or to bring mute control within easy reach
Logitech Rally Plus - video conferencing kit
Video conferencing kit
Video Input
Digital video camera - SuperSpeed USB 3.0
Audio Input
Three microphones
Audio Output
Speaker(s)
Input Device
Remote control (wired)
Video Input
Digital video camera (colour) - desktop
Interface Type
SuperSpeed USB 3.0
Digital Video Capture Resolution
3840 x 2160
Audio Input
Three microphones - external
Frequency Response
90 - 16000 Hz
Audio Output
Speaker(s)
Input Device
Remote control
Wired
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x microphone , 2 x display / video - HDMI , 1 x USB 3.1 - 24 pin USB-C , 1 x USB 3.1 - 9 pin USB Type A , 2 x USB 3.1 - 9 pin USB Type B , 2 x audio
1 x USB-C 3.1 cable - 2 m , 1 x USB 3.1 Type A to Type B cable - 2 m , 2 x audio cable - 2.95 m , 1 x network cable - 5 m , 2 x HDMI cable - 2 m , 1 x microphone cable - 2.95 m
Power supply
Shipping Width
21 cm
Shipping Depth
69 cm
Shipping Height
40 cm
Shipping Weight
11.2 kg
Brand: Logitech
Price Range Ex VAT: 1500+
