Your basket is empty
Logitech R400 Wireless Presenter - Remote Control
Wireless Presenter R400
Quicklinx: 65RTWS00 Mfr#: 910-001356
Recommended Use: Office
Type: Wireless Presenter
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
5 on order, delivery delayed
£39.79 ex VAT
£47.74 inc VAT
Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last.
It'll be easy for your audience to see exactly what you're pointing to.
The 2.4 GHz wireless allows you to enjoy the freedom to move around the room and mingle with your audience for greater impact.
Lets you know how much power is available with just a glance.
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter.
Logitech Wireless Presenter R400 - presentation remote control
Presentation remote control
Radio
Supported Devices
Personal computer
Max Operating Distance
15 m
Standard - AAA type
Microsoft Certification
Compatible with Windows 7
3 years warranty
Radio
Supported Devices
Personal computer
15 m
Battery level indicator, built-in laser pointer, LED indicator
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista
Carrying case, 2 AAA batteries, wireless receiver
Standard - AAA type
Included Qty
2
Limited warranty - 3 years
Colour: Black
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 0 - 50
