Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last.
It'll be easy for your audience to see exactly what you're pointing to.
The 2.4 GHz wireless allows you to enjoy the freedom to move around the room and mingle with your audience for greater impact.
Lets you know how much power is available with just a glance.
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter.
Intuitive slideshow controls
Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last -
Red laser pointer
It'll be easy for your audience to see exactly what you're pointing to. 1 -
Up to 15-meter range
The 2.4 GHz wireless allows you to enjoy the freedom to move around the room and mingle with your audience for greater impact -
Battery indicator
Lets you know how much power is available with just a glance -
Plug-and-play wireless receiver
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter -
Confidence boost
Intuitive controls and red laser pointer make presentations a snap, even in the darkest auditoriums -
Move freely
The 15-meter range and battery indicator help you make ordinary presentations extraordinary -
Ready to go
No software needed, just plug the receiver into a USB port and you're ready to go
- Logitech Wireless Presenter R400 - presentation remote control
- Presentation remote control
- 11.55 cm x 3.78 cm x 2.74 cm
- 57 g
- Connectivity Technology
- Radio
- Supported Devices
- Personal computer
- Max Operating Distance
- 15 m
- Battery
- Standard - AAA type Alkaline
- Microsoft Certification
- Compatible with Windows 7
- 3 years warranty
- 11.55 cm
- 3.78 cm
- 2.74 cm
- 57 g
- Radio
- Supported Devices
- Personal computer
- 15 m
- Battery level indicator, built-in laser pointer, LED indicator
- Operating System
- MS Windows XP, MS Windows 7, MS Windows Vista
- Included Accessories
- Carrying case, 2 AAA batteries, wireless receiver
- Battery
- Included Qty
- 2
- Limited warranty - 3 years
