Product
Logitech R400 Wireless Presenter - Remote Control
Quicklinx: 65RTWS00 Mfr#: 910-001356
Recommended Use: Office
Type: Wireless Presenter
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
More than 50 in stock
£33.15 ex VAT
£39.78 inc VAT
Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last.
It'll be easy for your audience to see exactly what you're pointing to.
The 2.4 GHz wireless allows you to enjoy the freedom to move around the room and mingle with your audience for greater impact.
Lets you know how much power is available with just a glance.
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter.
  • Intuitive slideshow controls
  • Red laser pointer
    It'll be easy for your audience to see exactly what you're pointing to. 1
  • Up to 15-meter range
  • Battery indicator
  • Plug-and-play wireless receiver
  • Confidence boost
    Intuitive controls and red laser pointer make presentations a snap, even in the darkest auditoriums
  • Move freely
    The 15-meter range and battery indicator help you make ordinary presentations extraordinary
  • Ready to go
    No software needed, just plug the receiver into a USB port and you're ready to go
Logitech Wireless Presenter R400 - presentation remote control
Presentation remote control
11.55 cm x 3.78 cm x 2.74 cm
57 g
Radio
Supported Devices
Personal computer
Max Operating Distance
15 m
Standard - AAA type Alkaline
Microsoft Certification
Compatible with Windows 7
3 years warranty
11.55 cm
3.78 cm
2.74 cm
57 g
Radio
Supported Devices
Personal computer
15 m
Battery level indicator, built-in laser pointer, LED indicator
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista
Carrying case, 2 AAA batteries, wireless receiver
Included Qty
2
Limited warranty - 3 years
Colour: Black
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 0 - 50
