The Logitech PTZ Pro Camera is a premium USB-enabled HD 1080p PTZ video camera for use in conference rooms, education, health care and other professional video workspaces. The PTZ camera features a wide 90° field of view, 10x lossless full HD zoom, ZEISS optics with autofocus, smooth mechanical 260° pan and 130° tilt, H.264 UVC 1.5 with Scalable Video Coding, remote control, far-end camera control plus multiple presets and camera mounting options for custom installation.
Set-up is a snap with plug-and-play simplicity and a single USB cable-to-host connection. Leading business certifications - Certified for Skype for Business, Optimized for Lync, Skype certified, Cisco Jabber and WebEx compatible - ensure an integrated experience with most business-grade UC applications.
FOR ANY ENVIRONMENT
If you're considering video for a meeting space, conference, classroom, or training environment, you can count on PTZ Pro Camera. It is suitable for large and small spaces or any office or professional situation that requires professional-quality video -
CERTIFIED FOR BUSINESS
Certifications ensure PTZ Pro Camera works with most VC applications. Chances are it's compatible with the application you already use. Certifications include: Certified for Skype for Business; Optimized for Microsoft Lync ; Skype certified; Cisco Jabber and WebEx compatible -
CAPTURE ALL THE ACTION
Get full visibility in any room or space. PTZ Pro Camera provides 1080p video with 90-degree field of view, 260-degree pan and 130-degree tilt. Zoom wide or zero in with 10x full HD lossless zoom. The high-precision lens automatically focuses on people and objects to deliver sharp resolution -
REMOTE CONTROL FOR EASY OPERATION
Control functions such as pan, tilt, and zoom using the hand-held remote. Recall up to three preset viewing angles easily. You can also operate the camera from a remote location using software such as Skype for Business and Microsoft, Lync
- Logitech PTZ Pro Camera - videoconferencing camera
- Videoconferencing camera - pan / tilt / zoom
- Camera Mount Type
- Tripod mount
- 13 cm x 13 cm x 15 cm
- 590 g
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 10 x
- Max Resolution
- 1920 x 1080
- Frame Rate
- 30 frames per second
- Video Modes
- 1080p
- Focal Length Control
- Motorized zoom
- Focus Adjustment
- Automatic
- Panning Range (degree)
- 260
- Tilting Range (degree)
- 130
- USB 2.0
- Cables Included
- 1 - speaker cable - external - 4.88 m , 1 - video cable - external - 4.88 m , 1 - USB cable - external - 3 m
- Full duplex audio, Bluetooth ready, security lock slot (cable lock sold separately), Jabber compatible, WebEx compatible, Skype compatible
- Audio Support
- Yes : built-in speaker, two-way audio capability, built-in dual stereo microphones
- Camera Mount Type
- Tripod mount
- Wired
- 13 cm
- 13 cm
- 15 cm
- 590 g
Camera
- Colour - pan / tilt / zoom
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Modes
- 1080p
- Video Capture
- 1920 x 1080 @ 30 fps
Lens Construction
- Motorized zoom
- Optical Zoom
- 10 x
- Focus Adjustment
- Automatic
Panning
- Range (degree)
- 260
Titling
- Range (degree)
- 130
- Computer Interface
- USB 2.0
- Included Accessories
- Remote control, wall/table mount
- Cables Included
- 1 x speaker cable - external - 4.88 m , 1 x video cable - external - 4.88 m , 1 x USB cable - external - 3 m
- Plug and Play
- Power Device
- Power adapter - external
- OS Required
- Google Chrome OS, Apple MacOS X 10.7 or later, Microsoft Windows 7 / Windows 8
- System Requirements Details
- MacOS X 10.7 or later - Core 2 Duo - 2.4 GHz - RAM 2 GB , Chrome OS - Core 2 Duo - 2.4 GHz - RAM 2 GB , Windows 7/8 - Core 2 Duo - 2.4 GHz - RAM 2 GB
