Logitech PTZ Pro Camera
Quicklinx: BGYWWS00 Mfr#: 960-001022
The Logitech PTZ Pro Camera is a premium USB-enabled HD 1080p PTZ video camera for use in conference rooms, education, health care and other professional video workspaces. The PTZ camera features a wide 90° field of view, 10x lossless full HD zoom, ZEISS optics with autofocus, smooth mechanical 260° pan and 130° tilt, H.264 UVC 1.5 with Scalable Video Coding, remote control, far-end camera control plus multiple presets and camera mounting options for custom installation.
Set-up is a snap with plug-and-play simplicity and a single USB cable-to-host connection. Leading business certifications - Certified for Skype for Business, Optimized for Lync, Skype certified, Cisco Jabber and WebEx compatible - ensure an integrated experience with most business-grade UC applications.
  • FOR ANY ENVIRONMENT
    If you're considering video for a meeting space, conference, classroom, or training environment, you can count on PTZ Pro Camera. It is suitable for large and small spaces or any office or professional situation that requires professional-quality video
  • CERTIFIED FOR BUSINESS
    Certifications ensure PTZ Pro Camera works with most VC applications. Chances are it's compatible with the application you already use. Certifications include: Certified for Skype for Business; Optimized for Microsoft Lync ; Skype certified; Cisco Jabber and WebEx compatible
  • CAPTURE ALL THE ACTION
    Get full visibility in any room or space. PTZ Pro Camera provides 1080p video with 90-degree field of view, 260-degree pan and 130-degree tilt. Zoom wide or zero in with 10x full HD lossless zoom. The high-precision lens automatically focuses on people and objects to deliver sharp resolution
  • REMOTE CONTROL FOR EASY OPERATION
    Control functions such as pan, tilt, and zoom using the hand-held remote. Recall up to three preset viewing angles easily. You can also operate the camera from a remote location using software such as Skype for Business and Microsoft, Lync
Logitech PTZ Pro Camera - videoconferencing camera
Videoconferencing camera - pan / tilt / zoom
Camera Mount Type
Tripod mount
13 cm x 13 cm x 15 cm
590 g
Wired
Camera
Optical Zoom
10 x
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Video Modes
1080p
Focal Length Control
Motorized zoom
Focus Adjustment
Automatic
Panning Range (degree)
260
Tilting Range (degree)
130
USB 2.0
1 - speaker cable - external - 4.88 m , 1 - video cable - external - 4.88 m , 1 - USB cable - external - 3 m
Full duplex audio, Bluetooth ready, security lock slot (cable lock sold separately), Jabber compatible, WebEx compatible, Skype compatible
Audio Support
Yes : built-in speaker, two-way audio capability, built-in dual stereo microphones
Camera Mount Type
Tripod mount
Wired
13 cm
13 cm
15 cm
590 g
Camera
Colour - pan / tilt / zoom
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
1080p
Video Capture
1920 x 1080 @ 30 fps
Lens Construction
Motorized zoom
Optical Zoom
10 x
Focus Adjustment
Automatic
Panning
Range (degree)
260
Titling
Range (degree)
130
Computer Interface
USB 2.0
Remote control, wall/table mount
1 x speaker cable - external - 4.88 m , 1 x video cable - external - 4.88 m , 1 x USB cable - external - 3 m
Plug and Play
Power adapter - external
Google Chrome OS, Apple MacOS X 10.7 or later, Microsoft Windows 7 / Windows 8
System Requirements Details
MacOS X 10.7 or later - Core 2 Duo - 2.4 GHz - RAM 2 GB , Chrome OS - Core 2 Duo - 2.4 GHz - RAM 2 GB , Windows 7/8 - Core 2 Duo - 2.4 GHz - RAM 2 GB
