A wireless presenter comes with a brilliant laser and intuitive slideshow controls - that helps you make high-impact presentations.
Brilliant red laser pointer
Your audience will see exactly where you point. 1 -
LCD display
Keep track of time, battery, and wireless reception with a glance or with silent, vibrating alerts. You remain focused on your presentation, not the clock -
Up to 100-foot (30-meter) range
You'll enjoy the freedom to move around the room and mingle with your audience for greater impact. A reception-level indicator ensures you don't wander too far -
Intuitive slideshow controls
Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last -
Plug-and-play wireless receiver
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter -
Make your point
Brilliant red laser pointer helps you get their attention-and keep it -
You're in control
Navigate through your presentation with confidence with the intuitive slideshow controls -
Work the crowd
The 100-foot (30-meter) range helps you make ordinary presentations extraordinary
- Logitech Professional Presenter R700 presentation remote control
- Presentation remote control
- 3.8 cm x 13.4 cm x 2.8 cm
- 71 g
- Connectivity Technology
- Radio
- Supported Devices
- Personal computer
- Max Operating Distance
- 30 m
- Battery
- Standard - AAA type
- 3-year warranty
- 3.8 cm
- 13.4 cm
- 2.8 cm
- 71 g
- Radio
- Supported Devices
- Personal computer
- 30 m
- Battery level indicator, LCD display, built-in laser pointer, vibration alert, timer
- Operating System
- MS Windows XP, MS Windows 7, MS Windows Vista, Windows 8, Windows RT
- Included Accessories
- Carrying case, 2 AAA batteries, wireless receiver
- Battery
- Included Qty
- 2
- Limited warranty - 3 years
