Logitech Professional Presenter R700
POWERFUL CONTROL FOR HIGH IMPACT PRESENTATIONS
Quicklinx: 8YVXWS00 Mfr#: 910-003506
A wireless presenter comes with a brilliant laser and intuitive slideshow controls - that helps you make high-impact presentations.
  • Brilliant red laser pointer
    Your audience will see exactly where you point. 1
  • LCD display
    Keep track of time, battery, and wireless reception with a glance or with silent, vibrating alerts. You remain focused on your presentation, not the clock
  • Up to 100-foot (30-meter) range
    You'll enjoy the freedom to move around the room and mingle with your audience for greater impact. A reception-level indicator ensures you don't wander too far
  • Intuitive slideshow controls
    Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last
  • Plug-and-play wireless receiver
    There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter
  • Make your point
    Brilliant red laser pointer helps you get their attention-and keep it
  • You're in control
    Navigate through your presentation with confidence with the intuitive slideshow controls
  • Work the crowd
    The 100-foot (30-meter) range helps you make ordinary presentations extraordinary
Logitech Professional Presenter R700 presentation remote control
Presentation remote control
3.8 cm x 13.4 cm x 2.8 cm
71 g
Radio
Supported Devices
Personal computer
Max Operating Distance
30 m
Standard - AAA type
3-year warranty
3.8 cm
13.4 cm
2.8 cm
71 g
Radio
Supported Devices
Personal computer
30 m
Battery level indicator, LCD display, built-in laser pointer, vibration alert, timer
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista, Windows 8, Windows RT
Carrying case, 2 AAA batteries, wireless receiver
Standard - AAA type
Included Qty
2
Limited warranty - 3 years
