E.P.S. helps protect both the front and back of your tablet from accidental bumps, scratches and spills. When surprises come your way, we've got you covered.
Lightweight clips keep the corners of your tablet firmly fastened to the frame, yet the tablet is easy to insert and remove.
Slim design
Precision engineering and state-of-the-art materials make this folio amazingly slim. -
Essential Protection System (E.P.S.)
E.P.S. helps protect both the front and back of your tablet from accidental bumps, scratches and spills. When surprises come your way, we've got you covered. -
Dual-view stand
Stand your tablet upright at an ideal typing angle. Or lay it flat to hide the keyboard, then draw, read, or browse in comfort. -
SecureLock system
- Logitech Pro - keyboard and folio case - UK
- Keyboard and folio case
- Interface
- Bluetooth
- Localization and Layout
- UK
- 22 cm x 2.2 cm x 30.4 cm
- 583 g
- 2-year warranty
- Designed For
- Samsung Galaxy NotePRO (12.2 in), TabPRO (12.2 in)
- Interface
- Bluetooth
Input Device
- UK
- 22 cm
- 2.2 cm
- 30.4 cm
- 583 g
Carrying Case
- Scratch-proof, corner protection system, transformable into a stand for typing or viewing video, spill-resistant
- Cables Included
- 1 x USB charge cable
- OS Required
- Android 4.4 (KitKat)
- Limited warranty - 2 years
- Designed For
