Product
Logitech Pop Home Add-on Switch - Coral
Quicklinx: CTS8WS00 Mfr#: 915-000288
Type: Smart switch
Compatible With: Apple Homekit, IFTTT
Colours:
£30.22 ex VAT
£36.26 inc VAT
POP Home Switch lets everyone in the home control smart lighting, music, and more with the push of a button. Program each switch with up to three custom commands to add creativity and convenience throughout your smart home. Whether it's movies, reading, or a party, POP makes it easy to match lighting with lifestyle. Configure your lights for brightness, warmth, and color and enjoy simple push-button control. Program POP to play your favorite music at just the right volume. Add lighting to the mix to create Recipes that instantly set the mood, from early morning waking up, to late night rocking out. Create Recipe combinations to trigger multiple smart devices at once, like setting smart locks and night-lights before going to bed.
Because each switch is wireless and battery-powered, you can use POP just about anywhere. Mount one by the front door, keep one on your nightstand, or carry one from room to room. Add simple smart home control wherever you like. POP Home Switch combines with the POP bridge and POP app, to deliver powerful functionality that is effortless to use. Use the POP app to scan for devices. Drag-and-drop to add to a POP home switch, or create a multi-device Recipe. Press once, press twice or press-and-hold to trigger different preset commands. Each switch's replaceable battery lasts for years with typical household use.
  • POP THE LIGHTS
    Whether it's movies, reading, or a party, POP makes it easy to match lighting with lifestyle. Use the POP app to configure your Philips Hue , Insteon , LIFX, or Lutron lights for brightness, warmth, and colour-then enjoy simple push-button control
  • POP THE MUSIC
    Program POP to play your Sonos favorites at just the right volume. Add lighting to the mix to create Recipes that instantly set the mood, from early morning waking up, to late night rocking out
  • POP EVERYTHING, TOGETHER
    Want to set the mood with lights AND music? Create Recipe combinations to trigger multiple smart devices at once, like setting smart locks and night-lights before going to bed. Or, when combined with a Harmony hub-based remote, use POP to start an Activity like "Movie Night "– the TV, cable and stereo turn on and smart lights dim
  • POP NEARLY ANYWHERE
    Because each switch is wireless and battery-powered, you can use POP just about anywhere. Mount one by the front door, keep one on your nightstand, or carry one from room to room. Use POP Add-On switches to add simple smart home control wherever you like
Logitech POP Add-on Home Switch - switch
Switch
Power Source
Wireless - Bluetooth, Wi-Fi
Supported Host Device OS
iOS, Android
Coral
1 year warranty
6 cm x 0.9 cm x 6 cm
Switch
Power Source
Wireless - Bluetooth, WiFi
Android 4.4 (KitKat) or later, iOS 9 or later
Mounting tape
Coral
Warranty
1 year warranty
6 cm
0.9 cm
6 cm
37 g
Type: Smart switch
Compatible With: IFTTT
Brand: Logitech
Price Range Ex VAT: 0 - 50
