High-performance design
Enjoy precision control and comfort thanks to the hand-sculpted design and well-positioned buttons and wheels -
Darkfield Laser Tracking
Turn the world into your mouse pad: works on virtually any surface with precise cursor control-even on glass and high-gloss surfaces. 4 mm minimum thickness -
Smart speed-adaptive scroll wheel
Navigate through long documents and web pages faster and easier with a precision scroll wheel that auto-shifts from click-to-click to hyper-fast scrolling -
Unique thumb wheel
Experience side-to-side scrolling with a stroke of your thumb. To unlock the full range of thumb wheel possibilities, install Logitech Options software -
Customizable functions
Unlock the full range of possibilities and customize the mouse to your needs with Logitech Options software -
Dual connectivity
Connect the wireless mouse quickly and easily with the included Logitech Unifying receiver or via Bluetooth Smart wireless technology -
Easy-Switch technology
Pair up to three devices (such as a desktop, laptop or a Windows tablet) and easily switch between them with the touch of a button -
Rechargeable battery
Fast-charge the battery with enough power for a full workday in just 4 minutes. The battery can last up to 40 days on a full charge. Battery life may vary based on user and computing conditions -
Optimized productivity for Windows and Mac
Enterprise ready and plug-and-play compatible with leading Microsoft operating systems and Mac OS X 10.8 or later -
Turn the world into your mouse pad: Works on virtually any surface with precise cursor control-even on glass and high-gloss surfaces. 4 mm minimum thickness
- Logitech MX Master - mouse - Bluetooth, 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - Bluetooth, 2.4 GHz
- 8.57 cm x 12.6 cm x 4.84 cm
- 145 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 5
- Movement Resolution
- 1600 dpi
- Performance
- Realtime sensitivity switching 400 - 1600 dpi
- Logitech Darkfield Laser Tracking, Logitech Unifying receiver, side wheel, Easy-Switch technology, gesture function, Smart Speed Adaptive Scroll Wheel, Bluetooth Smart (Windows 8, Windows 10 or later / Mac OS X 10.10 or later required)
- OS Required
- Microsoft Windows 7, Windows 8, Apple MacOS X 10.8 or later, Windows 10 or later
- 2-year warranty
- Mouse
- Wireless Receiver
- 8.57 cm
- 12.6 cm
- 4.84 cm
- 145 g
Input Device
- Wireless
- Interface
- Max Operating Distance
- Up to 10 m
- Laser
- Buttons Qty
- 5
- 1600 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Micro-USB cable
- Technology
- Lithium polymer
- Capacity
- 500 mAh
- Run Time (Up To)
- 40 days
- OS Required
- Limited warranty - 2 years
