Logitech MX Anywhere 2S Bluetooth Mouse - Light Grey
Quicklinx: DC0MWS00 Mfr#: 910-005155
Wired / Wireless: Wireless
Colour: Light grey
10 in stock
£64.33 ex VAT
£77.19 inc VAT
Harness the power of Logitech Flow and seamlessly move content between three devices. Fly through documents with hyper-fast scrolling. Work comfortably for hours thanks to a compact, sculpted shape and long-lasting rechargeable battery.
  • EFFORTLESS MULTI-COMPUTER WORKFLOW
    Gone are the days when working across several computers meant sending yourself cumbersome emails with attachments or tediously copying files on a flash drive. With Logitech Flow you can move your mouse cursor across three computer screens and even copy/paste text, images and files from one computer to the other
  • DARKFIELD HIGH-PRECISION TRACKING
    A premium mouse deserves the best quality tracking. That's why we designed the MX Anywhere 2S with a brand new, 4000 DPI precision sensor that can track everywhere – even on a sleek boardroom glass table
  • RECHARGEABLE BATTERY
    The quick-recharging battery means MX Anywhere 2S is ready when you are. Get enough power for a full day of work in only 3 minutes, with no downtime while recharging. A full charge can last up to 70 days. To recharge, just plug the mouse into your computer using the micro-USB charging cable and continue using it while it charges
  • HYPER-FAST SCROLLING
    Scroll through long documents or web pages faster and easier. Or, press the wheel and shift to click-to-click mode for precise navigation. In free-spinning mode, you coast smoothly and quickly through the longest documents and web pages, stopping instantly when you need to. In click-to-click mode, you can scroll precisely through spreadsheets or databases
  • EASY-SWITCH AND DUAL CONNECTIVITY
    Connect MX Anywhere 2S via the included Logitech Unifying Receiver or Bluetooth low energy technology. Thanks to Logitech Easy-Switch technology, pair up to 3 devices and easily switch between them with the touch of a button
  • COMPACT, SCULPTED SHAPE
    Compact enough to take anywhere, this wireless mobile mouse is designed to help you make things happen at work or on the go
Logitech MX Anywhere 2S - mouse - Bluetooth, 2.4 GHz - light grey
Mouse
Wireless - Bluetooth, 2.4 GHz
Light grey
6.16 cm x 10.03 cm x 3.44 cm
106 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 200 - 4000 dpi
Scrolling wheel, Logitech Darkfield Laser Tracking, battery indicator, turbo scroll, Logitech Unifying receiver, Easy-Switch technology
Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.10 or later
Mouse
Wireless Receiver
6.16 cm
10.03 cm
3.44 cm
106 g
Light grey
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
1 x USB - 4 pin USB Type A
Micro-USB cable
Lithium polymer
500 mAh
Run Time (Up To)
70 days
Colour: Light grey
Brand: Logitech
Price Range Ex VAT: 50 - 100
