Logitech MX Anywhere 2 Mouse
Quicklinx: BL9NWS00 Mfr#: 910-004374
Darkfield laser tracking gives you flawless control on virtually any surface, including glass and high-gloss surfaces. This wireless travel mouse performs anywhere you need it to - glass tables in your hotel room, shiny laminate tops, train and airplane tray tables, and even your jeans. Unlike traditional laser and optical mice which use irregularities on the surface to track mouse movements, Darkfield technology uses the smallest possible detail to create a micro-road map of the surface.
  • Tracks virtually anywhere
    Darkfield laser tracking gives you flawless control on virtually any surface, including glass and high-gloss surfaces. This wireless travel mouse performs anywhere you need it to-glass tables in your hotel room, shiny laminate tops, train and airplane tray tables, and even your jeans. Unlike traditional laser and optical mice which use irregularities on the surface to track mouse movements, Darkfield technology uses the smallest possible detail to create a micro-road map of the surface. In tests, the mouse performed best on glass with a minimum thickness of 4mm
  • Compact, sculpted shape
    Compact enough to take with you anywhere, this wireless mobile mouse is designed to help you make things happen anywhere-at home, at work, or on the go
  • Dual connectivity and Easy-Switch technology
    Connect this performance mouse via included Logitech Unifying Receiver or via Bluetooth Smart wireless technology. Thanks to Logitech Easy-Switch technology pair up to three devices and easily switch between them with the touch of a button
  • Hyper-fast scroll
    Scroll through long documents or web pages faster and easier. Or, press the wheel and shift to click-to-click mode for precise navigation. In free-spinning mode, you coast smoothly and quickly through the longest documents and Web pages, stopping instantly when you need to. In click-to-click mode you can scroll precisely through spreadsheets, photo albums or playlists
  • Rechargeable battery
    Charge quickly and get enough power for a full day of usage in only 4 minutes, with no down time while recharging. A full charge can last up to 2 months. When the battery gets low, an indicator light lets you know. Recharging is fast and easy. Just plug MX Anywhere 2 into your computer using the micro-USB charging cable. Continue using your mouse while it charges
Logitech MX Anywhere 2 - mouse - Bluetooth, 2.4 GHz - black
Mouse
Wireless - Bluetooth, 2.4 GHz
6.16 cm x 10.03 cm x 3.44 cm
106 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Buttons Qty
6
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 400 - 1600 dpi
Scrolling wheel, Logitech Darkfield Laser Tracking, Logitech Unifying receiver, Easy-Switch technology, gesture function
Apple MacOS X 10.8 or later, Microsoft Windows 7 / 8 / 10 or later
Mouse
Wireless Receiver
6.16 cm
10.03 cm
3.44 cm
106 g
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
6
Movement Resolution
1600 dpi
Performance
1 x USB - 4 pin USB Type A
Micro-USB cable
Lithium polymer
500 mAh
Run Time (Up To)
2 months
