Logitech Multimedia Speakers Z213 - Analog - UK
Quicklinx: BGXHWS00 Mfr#: 980-000943
Feel full bass. A down-facing subwoofer with a 4" driver provides a rich bass experience with these 2.1 speakers. Don't sacrifice valuable desk space for great sound. The inclined design of Z213 directs sound right to your ears.
  • Full Sound
    14Watts Peak /7Watts RMS power delivers clear audio and enhanced bass from the down-firing subwoofer. Connect your device via the 3.5mm input and enjoy a full audio experience in a small form factor
  • Simple Controls
    Easily access power, volume and the headphone jack using the wired control pod. Customize your listening experience by adjusting the bass level with the dedicated control knob on the back of the subwoofer
  • Perfect Fit
    Enjoy better sound in your entire workspace. This 2.1 speaker system is the perfect fit for small spaces. Compact speakers take up minimal space on the desktop and the subwoofer fits right under the desk
Logitech Z213 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
7 Watt
Audio System Peak Power (Total)
14 Watt
Frequency Response
65 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 x satellite speaker 1.5 Watt 4 Ohm , 1 x subwoofer 4 Watt 4 Ohm
1.76 kg
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
7 Watt
14 Watt
Frequency Response
65 - 20000 Hz
Amplifier
Integrated
Controls
Power on/off, volume, bass
Additional Features
British plug type
Speakers Included
2 x satellite speaker - 1.5 Watt - 4 Ohm - wired , 1 x subwoofer - 4 Watt - 4 Ohm - wired
Driver Details
Satellite speaker: full-range driver - 2"
Driver Details (2nd speaker)
Subwoofer: subwoofer driver - 4"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
Cable remote control
Power Source
AC power adapter
1.76 kg
Dimensions (WxDxH) / Weight Details
Satellite speaker: 7.9 cm x 7.6 cm x 14.2 cm , Subwoofer: 13 cm x 19.3 cm x 18.3 cm
