Feel full bass. A down-facing subwoofer with a 4" driver provides a rich bass experience with these 2.1 speakers. Don't sacrifice valuable desk space for great sound. The inclined design of Z213 directs sound right to your ears.
Full Sound
14Watts Peak /7Watts RMS power delivers clear audio and enhanced bass from the down-firing subwoofer. Connect your device via the 3.5mm input and enjoy a full audio experience in a small form factor -
Simple Controls
Easily access power, volume and the headphone jack using the wired control pod. Customize your listening experience by adjusting the bass level with the dedicated control knob on the back of the subwoofer -
Perfect Fit
Enjoy better sound in your entire workspace. This 2.1 speaker system is the perfect fit for small spaces. Compact speakers take up minimal space on the desktop and the subwoofer fits right under the desk
- Logitech Z213 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 7 Watt
- Audio System Peak Power (Total)
- 14 Watt
- Frequency Response
- 65 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 1.5 Watt 4 Ohm , 1 x subwoofer 4 Watt 4 Ohm
- 1.76 kg
- 2-year warranty
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 7 Watt
- 14 Watt
- 65 - 20000 Hz
- Amplifier
- Integrated
- Controls
- Power on/off, volume, bass
- Additional Features
- British plug type
- Speakers Included
- 2 x satellite speaker - 1.5 Watt - 4 Ohm - wired , 1 x subwoofer - 4 Watt - 4 Ohm - wired
- Driver Details
- Satellite speaker: full-range driver - 2"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 4"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Cable remote control
- Power Source
- AC power adapter
- 1.76 kg
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 7.9 cm x 7.6 cm x 14.2 cm , Subwoofer: 13 cm x 19.3 cm x 18.3 cm
- Limited warranty - 2 years
