Work or play in more places. The wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10-meters range.
Take the mouse with you. This comfortable mouse fits easily into computer bags and pocket to travel with your computer.
A 24-month keyboard and 12-month mouse battery life - plus on/off switches - means you can go for months without the hassle of changing batteries.
Instant access to media controls - movies, music, Internet, e-mail, play/pause, volume and more - are one touch away.
The full-size keyboard with number pad, directional keys, and nine F-keys is comfortable, convenient and built to last.
Advanced 2.4 GHz wireless
Work or play in more places. The wireless connection virtually eliminates delays, dropouts and interference and gives you a range of up to 10-meters range. 1 -
Compact mouse
Take the mouse with you. This comfortable mouse fits easily into computer bags and pocket to travel with your computer -
Extended battery life
A 36-month keyboard and 12-month mouse battery life-plus on/off switches-means you can go for months without the hassle of changing batteries -
Eight shortcut keys
Instant access to media controls-movies, music, Internet, e-mail, play/pause, volume and more-are one touch away -
Full-size keyboard
The full-size keyboard with number pad, directional keys, and nine F-keys is comfortable, convenient and built to last -
Long-range wireless
Fast, reliable connection up to 10-meters with virtually no delays or dropouts thanks to Logitech Advanced 2.4 wireless technology -
On-the-go mouse
Take this compact mouse anywhere your computer goes -
Long battery life
Go for months without changing batteries. On/Off switches help conserve battery use
- Logitech Wireless Combo MK270 - keyboard and mouse set - UK English
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Input Device
- Keyboard - wireless
- Layout
- UK English
- Hot Keys Qty
- 8
- Hot Keys Function
- Internet browsing, calculator, e-mail, volume, mute, play/pause
- On/off power switch
- Pointing Device
- Mouse - optical
- Buttons Qty
- 3
- Scrolling wheel, wireless, on/off power switch, 1000 dpi resolution
- 3-year warranty
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 44.1 cm x 14.9 cm x 1.8 cm / 481 g , Mouse: 6 cm x 9.9 cm x 3.9 cm / 50 g , Wireless receiver: 1.4 cm x 1.9 cm x 0.6 cm / 2 g
Input Device
- Keyboard Name
- Logitech Wireless Keyboard K270
- Hot Keys Qty
- 8
- Hot Keys Function
- Layout
- UK English
Pointing Device
- Mouse
- Pointing Device Name
- Logitech Wireless Mouse M185
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Pointing Device Features
- Included Accessories
- USB extender
- Plug and Play
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- AA / AAA
- Installed Qty
- 3
- Required Qty
- 3
- Technology
- Alkaline
- Limited warranty - 3 years
