Logitech M720 Triathlon Bluetooth Mouse
Quicklinx: D9CQWS00 Mfr#: 910-004791
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
Hurry, only 3 left in stock!
£49.78 ex VAT
£59.73 inc VAT
Express delivery Order within the next 21 hours for delivery on Friday
Succeed in a multi-device world with M720 Triathlon Mouse. You'll power through tasks by switching seamlessly between 3 computers, and fly through documents and web pages with hyper-fast scrolling. Boosted efficiency means this Bluetooth and Unifying mouse lasts for 24 months on a single AA battery. All that in a full-size shape fitting comfortably under your hand.
  • Easy-Switch technology
    Pair your mouse with 3 computers, then switch seamlessly between them at a touch of the button conveniently positioned under your thumb. The 3 illuminated numbers always let you know to which device you're connected
  • Hyper-fast scrolling
    Fly through long documents and web pages with a spin of the wheel - and stop instantly - or switch to click-to-click scrolling when you need precision
  • Durable, sculpted design
    A true athlete, M720 is designed to endure, with buttons built to withstand up to 10 million clicks. The large-sized, right-hand design fits comfortably in your palm, the rubber surface making it extra soft to the touch
  • EFFORTLESS MULTI-COMPUTER WORKFLOW
    Unleash the potential of M720 with Logitech Flow, for the smoothest workflow between computers. You'll be able to move your mouse cursor across three computers and even copy/paste text, images and files from one computer to another. It's more efficient than sending yourself emails
  • 24-month battery life
    You'll like this mouse's boosted efficiency, with 24 months of power on a single AA battery
  • Personalized productivity
    Unlock the full range of possibilities and customize to fit your needs on Mac OS X and Windows by downloading Logitech Options Software. Set up and assign tasks to buttons with step-by-step instructions. An Immersion Guide is available to help answer your questions
Logitech M720 Triathlon - mouse - Bluetooth, 2.4 GHz
Mouse
Wireless - Bluetooth, 2.4 GHz
Orientation
Right-handed
7.4 cm x 11.5 cm x 4.5 cm
135 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
1000 dpi
Scrolling wheel, battery indicator, rubber coating, on/off power switch, Logitech Unifying receiver, Logitech Advanced Optical Tracking, Easy-Switch technology, gesture function
AA type
Apple MacOS X 10.5 or later, Google Chrome OS, Android 5.0 or later, Microsoft Windows 7 / 8 / 10
1-year warranty
Mouse
Wireless Receiver
Orientation
Right-handed
7.4 cm
11.5 cm
4.5 cm
135 g
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
7
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
1 AA battery
AA type
Run Time (Up To)
2 years
Limited warranty - 1 year
Type: Mouse
Colour: Black
Compatibility: PC
Brand: Logitech
