Logitech M590 Silent Wireless Mouse - Graphite Tonal
Quicklinx: DNKNWS00 Mfr#: 910-005197
Hush... M590 Multi-Device Silent lets you get through your tasks with noiseless efficiency. Using Logitech Flow, it has the almost magical capacity to navigate seamlessly on two computers and copy-paste from one to the other. Its click noise reduction ensures, you won't be disturbing those around you.
  • LESS NOISE, MORE FOCUS
    Stay focused on your work without noise distractions. Logitech's own SilentTouch Technology reduces over 90% Sound level comparison between Logitech M590 and Logitech M170. Left click dBA measured by an independent lab at 1m. of clicking sounds, all while ensuring the mouse performs its best. That means you can feel every single click but hear virtually nothing
  • ALL-DAY COMFORT
    Designed for hours of comfort, M590 features a curved shape for great palm support, plus soft rubber side-grips and scroll wheel for superior control. The comfortable design is also compact and wireless, so you can perform anywhere - the office, at school, or behind your desk at home
  • CONNECT YOUR WAY
    Connect to your computer, laptop or tablet via Bluetooth wireless technology or the USB Unifying receiver, and never worry about annoying drop-offs or lag up to a 10m range Wireless range may vary based on environmental and computing conditions . So you can easily work on Windows , macOS , Chrome OS , Linux Customization of the buttons via Logitech Options is not possible on Linux. , Android and iPadOS
  • MULTI-DEVICE WORKFLOW
    M590 is designed for high performance. Enabled with Flow , M590 lets you move the cursor across two computers, Mac or PC, and seamlessly move text, images, and files from screen to screen. Easy-switch lets you pair your mouse to up to two devices and switch between them with a click
  • NEXT-LEVEL NAVIGATION
    M590 brings navigation and efficiency to the next level. The micro-precise scroll wheel packs more grooves per millimeter, making scrolling through long webpages faster and more precise. The tilt wheel offers easy horizontal side-to-side scrolling through web pages, large spreadsheets or images
  • QUALITY YOU CAN COUNT ON
    The mouse is built using the same high quality standards that have made Logitech the global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. . Durable and reliable, M590 also works up to 24 months Battery life may vary based on use and computing conditions. without changing batteries thanks to the auto-sleep power-saving mode and on/off switch button
  • Decades of Design Excellence
    We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
Logitech M590 Silent - mouse - Bluetooth, 2.4 GHz - graphite tonal
Mouse
Wireless - Bluetooth, 2.4 GHz
Graphite tonal
Orientation
Right-handed
6.4 cm x 10.3 cm x 4 cm
101 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
1000 dpi
Battery indicator, on/off power switch, Logitech Unifying receiver, Logitech Advanced Optical Tracking, precision scroll wheel
AA type
Google Chrome OS, Android 5.0 or later, Apple MacOS X 10.10 or later, Windows 8 / 10
Mouse
Wireless Receiver
Orientation
Right-handed
6.4 cm
10.3 cm
4 cm
101 g
Graphite tonal
Input Device
Wireless
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
7
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
AA type
Run Time (Up To)
24 months
