Logitech M570 Wireless Trackball
Wireless Trackball M570
Quicklinx: 77W6WS00 Mfr#: 910-001882
Recommended Use: Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Dark grey
Compatibility: Mac, PC
37 in stock
£49.93 ex VAT
£59.91 inc VAT
You've got a different kind of comfort thanks to a leave-in wireless receiver, long battery life and precise cursor control that lets you work - and play - wherever you want. The M570 now sports an adjustable laser sensor, giving you a wider range of cursor speeds - and the perfect amount of control.
  • Trackball comfort
    Your trackball stays in one place, so you don't have to move your arm to move your cursor. Its sculpted shape supports your hand to let you work all day in comfort
  • Compact footprint
    Short on space? No problem. Because the trackball doesn't move, it's perfect for tight workspaces and busy desks
  • Time-tested shape
    Millions of people have loved the Logitech Trackman Wheel. We've refined its proven shape to create the M570
  • Logitech Advanced 2.4 GHz wireless
    You get the reliability of a cord with cordless convenience and freedom-fast data transmission and virtually no delays or dropouts
  • Wireless freedom
    Who wants a cord in the way? The robust wireless connection lets you control your laptop, desktop computer or home theater PC from up to 30 feet (10 meters) away
  • Tiny, wireless receiver
    It's so small it can stay plugged in a USB port. You don't have to unplug it when you move around or worry about losing it. And your trackball is always ready to use
  • Logitech Unifying technology
    Easily connect up to six compatible wireless devices-keyboards, number pads or mice-without the hassle of multiple receivers filling up your USB ports
  • Storable receiver
    If you do need to remove the tiny receiver, just tuck it away right next to the battery
  • 18-month battery life
    The long battery life virtually eliminates the hassle of changing batteries. The On/Off button saves power, while an indicator light helps you avoid surprises. 1
  • Work-and play-anywhere
    You get precise cursor control wherever you want to use your trackball. Hard tables, comfy sofas and lumpy beds are all no problem for the M570
  • Adjustable speed
    The M570 now sports an adjustable laser sensor, giving you a wider range of cursor speeds-and the perfect amount of control
  • Scroll wheel
    You can easily move up and down through Web pages and long documents
  • Programmable buttons
    You can customize your trackball's buttons to help you do what you want faster
  • Back/Forward buttons
    Moving quickly between documents or browsing your favorite Web sites is a breeze with large, easy-to-reach Back/Forward buttons
  • Easy to clean
    Should you need to clean your trackball, removing the ball is a snap
  • Easy to move
    Your desk, your comfy chair, your bed-this trackball is easy to take with you around the home. The ball even stays in place when you turn it upside down
  • All-day comfort
    Work in comfort with a stable, sculpted trackball that supports your hand and lets you rest your arm
  • Small wonder
    Logitech Unifying receiver-the tiny, wireless receiver that stays in your laptop and lets you add compatible devices as you need them
  • Super powered
    With up to 18 months of use from a single AA, you might just forget your trackball uses batteries at all
Logitech Wireless Trackball M570 - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
Wireless Receiver
USB wireless receiver
Programmable buttons, trackball, scrolling wheel
1 x AA type
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Input Device
Wireless
2.4 GHz
1 x USB - 4 pin USB Type A
AA type
Installed Qty
1
Run Time (Up To)
18 months
Additional Requirements
USB port, Internet connection
Limited warranty - 3 years
Type: Mouse
Colour: Dark grey
Compatibility: Mac
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 0 - 50
