Perfect mix of performance, precision, price with a micro-precise scroll wheel for the ultimate online navigation experience and ergonomic shape! The innovative micro-precise wheel packs more grooves per millimeter giving, you the ultimate navigation experience. With its ergonomically shaped design and soft rubber grips, this mouse is built for comfort.
Micro-precise scroll wheel
With more grooves per millimeter, the scroll wheel gives you the ultimate navigation experience. It makes scrolling through long web pages faster and easier -
Ergonomically shaped
The ergonomically shaped design and soft rubber grips conform to your hand to be naturally comfortable, and the compact size makes it easy to take with you wherever you use your computer - at home, at work, or anywhere else. -
Long battery life
With the long-lasting battery, you can practically forget about changing batteries. Plus, the smart sleep mode saves power, while an indicator light eliminates surprises. -
Logitech Unifying receiver
The tiny receiver connects up to 6 Unifying-compatible devices. Add a keyboard, switch between mice, mix and match to fit your lifestyle. All without having to change nano receivers or sacrifice another USB port. -
Logitech advanced 2.4 GHz wireless
You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. -
Laser-grade tracking
Logitech advanced optical technology delivers laser-grade precision over the most challenging surfaces - including smooth, glossy surfaces - that are problematic for standard optical mice. All while using less power so you get longer battery life and more convenience. -
Page back/forward
To make surfing your favorite websites easier, you can move the tilt wheel left or right to move backward or forward while you're surfing the web.
- Logitech M525 - mouse - 2.4 GHz - white
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- White
- Localisation
- Western Europe
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Rubber side grips, scrolling wheel (4-way), battery indicator, Logitech Unifying receiver
- Battery
- 2 x AA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- White
- Localisation
- Western Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- 1 x USB - 4 pin USB Type A
- Plug and Play
- AA type
- Installed Qty
- 2
- Run Time (Up To)
- 3 years
- OS Required
- Limited warranty - 3 years
