Your basket is empty
Logitech M525 Wireless Mouse Blue
Quicklinx: 8YVFWS00 Mfr#: 910-002601
Perfect mix of performance, precision, price with a micro-precise scroll wheel for the ultimate online navigation experience and ergonomic shape! The innovative micro-precise wheel packs more grooves per millimeter giving, you the ultimate navigation experience. With its ergonomically shaped design and soft rubber grips, this mouse is built for comfort.
Logitech M525 - mouse - 2.4 GHz - blue
Mouse
Wireless - 2.4 GHz
Blue
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Scrolling wheel (4-way), battery indicator, Logitech Unifying receiver
2 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Blue
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
AA type
Installed Qty
2
Run Time (Up To)
3 years
Limited warranty - 3 years
