Logitech M525 Wireless Mouse Black
Quicklinx: 8YV9WS00 Mfr#: 910-002583
Perfect mix of performance, precision, price with a micro-precise scroll wheel for the ultimate online navigation experience and ergonomic shape! The innovative micro-precise wheel packs more grooves per millimeter giving, you the ultimate navigation experience. With its ergonomically shaped design and soft rubber grips, this mouse is built for comfort.
  • Micro-precise scroll wheel
    With more grooves per millimeter, our new scroll wheel gives you the ultimate navigation experience. It makes scrolling through long web pages faster and easier
  • Ergonomically shaped
    The ergonomically shaped design and soft rubber grips conform to your hand to be naturally comfortable, and the compact size makes it easy to take with you wherever you use your computer-at home, at work, or anywhere else
  • 3-year battery life
    With the world's longest-lasting battery, you can practically forget about changing batteries. Plus, the smart sleep mode saves power, while an indicator light eliminates surprises
  • Connect with ease
    You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it
  • Logitech Advanced 2.4 GHz wireless
    You get the reliability of a cord with wireless convenience and freedom-fast data transmission and virtually no delays or dropouts
  • Logitech Advanced Optical Technology
    Laser-grade precision tracks over the most challenging surfaces-including smooth, glossy surfaces-that are problematic for standard optical mice. All while using less power so you get longer battery life and more convenience
  • Page back/forward
    To make surfing your favorite websites easier, you can move the tilt wheel left or right to move backward or forward while you're surfing the Web
  • Scroll wheel for the control freak
    Our innovative micro-precise wheel packs more grooves per millimeter giving, you the ultimate navigation experience
  • Built for hands like yours
  • Go for years
    You'll get three years of battery life. It's so hassle free you might just forget it runs on batteries
  • More power
    You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it. Learn more about the Logitech Unifying receiver
Logitech M525 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Scrolling wheel (4-way), battery indicator, Logitech Unifying receiver
2 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
Plug and Play
AA type
Installed Qty
2
Run Time (Up To)
3 years
Limited warranty - 3 years
