Logitech M330 Silent Plus Wireless Mouse - Black
Quicklinx: CC98WS00 Mfr#: 910-004909
Recommended Use: Leisure, Office, Mobile
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
24 In Stock
£30.31 ex VAT
£36.37 inc VAT
Get all your work done without missing a beat or disturbing those around you. Silent Mice have the same click feel without the click noise - over 90% noise reduction. Durable, high performance feet quietly glide over the desktop. A smooth scroll wheel completes the silent experience. Silent Mice eliminate excess noise while protecting the health and productivity of everyone. Make this your last annoying click. Your family and friends will thank you.
  • Enjoy the sound of silence
    With the same click feel and over 90% noise reduction on the click sound, enjoy a quiet experience for you and your neighbors. Plus, it has feet made of high performance material and a rubber wheel for quiet gliding and scrolling
  • Crafted for your right hand
    Designed with contoured grips made of soft rubber for total comfort
  • 24-month battery life
    Go longer between battery changes thanks to energy efficient engineering. M330 SILENT PLUS automatically puts itself to sleep when not in use
  • Simple. Reliable. Strong
    Enjoy a wireless connection up to 10m away thanks to a plug-and-forget nano receiver. M330 SILENT PLUS features Logitech Advanced Optical Tracking for ultra precise moves on almost any surface. No hassle, no software needed. Works with Windows , Mac, Chrome OS or Linux -based computers
  • Quiet Mark Certification
    Logitech is the first mouse company in the world to receive the Quiet Mark certification. This international mark of approval from the UK Noise Abatement Society recognizes technology designed to reduce noise
Logitech M330 SILENT PLUS - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
6.79 cm x 10.54 cm x 3.84 cm
91 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Mechanical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, Nano wireless receiver
AA
Apple MacOS X 10.5 or later, Linux Kernel 2.6, Google Chrome OS, Microsoft Windows 7 / 8 / 10 or later
Mouse
Wireless Receiver
6.79 cm
10.54 cm
3.84 cm
91 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Mechanical
Buttons Qty
3
Movement Resolution
1000 dpi
AA
Run Time (Up To)
24 months
Recommended Use: Office
Recommended Use: Mobile
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Logitech
