Logitech M187 Wireless Mini Mouse Red
Quicklinx: 8YVKWS00 Mfr#: 910-002732
Type: Mouse
Wired / Wireless: Wireless
Colour: Red
Compatibility: Mac, PC
Colours:
15 in stock
£12.88 ex VAT
£15.45 inc VAT
The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability.
Say good-bye to cords and enjoy wireless freedom, so it's easy to use your mouse on the couch with your laptop - or even when you're hooking your laptop up to your TV.
  • Extra-small shape
  • Tiny nano receiver
    The nano receiver is so small it stays in your USB port-without worry of losing or breaking it. If you do need to remove it, it stores inside the mouse. You'll enjoy the freedom of wireless with more precision and control than your laptop's touchpad.
  • Logitech Advanced 2.4 GHz wireless
    Say good-bye to cords and enjoy wireless freedom (up to 10 meters (or 33 feet)), so it's easy to use your mouse on the couch with your laptop-or even when you're hooking your laptop up to your TV.
  • Logitech reliability
    You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty.
  • Goes wherever you go
    You can take the Mini Mouse wherever you take your laptop-thanks to its pocket-ready, extra-small design.
  • Free yourself
    The tiny nano receiver stays in your USB port-and lets you enjoy the freedom of wireless with more precision and control than your laptop's touchpad.
  • Confident connection
    Enjoy the reliability of a cord with the convenience of wireless-thanks to Logitech Advanced 2.4 GHz wireless technology.
Logitech M187 - mouse - 2.4 GHz - red
Mouse
Wireless - 2.4 GHz
Red
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Scrolling wheel, Nano wireless receiver
1 x AAA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Red
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
1 x USB - 4 pin USB Type A
AAA type
Installed Qty
1
Limited warranty - 3 years
Type: Mouse
Colour: Red
Compatibility: Mac
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 0 - 50
