Logitech M105 Mouse Blue
Quicklinx: 8YV5WS00 Mfr#: 910-003114
Type: Mouse
Wired / Wireless: Wired
Colour: Blue
Compatibility: Mac, PC, Unix
£9.85 ex VAT
£11.82 inc VAT
Just plug the mouse into a USB port and it's ready to use. No software or batteries required.
You'll enjoy smooth cursor control, precise tracking and easy text selection.
Your hand will be more comfortable than with your touchpad.
  • Simple to set up and use
    Setup is fast and easy-just plug the cable into a USB port. There's no software to install. And since it's corded, you can just plug the cable into a USB port and use it right away
  • High-definition optical tracking
    You'll enjoy responsive, smooth cursor control and precise tracking and easy text selection thanks to high-definition optical tracking (1000 dpi)
  • Full-size comfort, ambidextrous design
    Designed to keep either hand happy. So you'll feel comfortable, even after hours of use
  • Built by Logitech
    This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer
  • Plug and play
  • Logitech reliability
    You get a mouse you can count on with the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty
  • Smooth traveler
  • Comfy, contoured shape
Logitech M105 - mouse - USB - blue
Mouse
Wired - USB
Blue
Movement Detection Technology
Optical
Scrolling wheel
1 x USB cable - integrated
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Blue
Input Device
Wired
USB
Optical
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Limited warranty - 3 years
Type: Mouse
Colour: Blue
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Brand: Logitech
Price Range Ex VAT: 0 - 50
