The UC Keyboard K725-C enables quick voice and video commands right from the desktop using keys that control the headset, call functions, voicemail messages, and other UC features. Illuminated keys display call and video status, and a Plug-and-Play corded design eases use while saving space on the shrinking desktop.
The M525-C wireless mouse designed for Cisco Jabber delivers micro-precise scrolling and comfort for the all-day worker. An ergonomic design with soft rubber grips looks good and feels even better, while advanced optical tracking technology ensures efficient productivity. The included Logitech Unifying receiver also saves space by connecting to a USB port on the keyboard.
The C920-C webcam is designed exclusively for Cisco Jabber to support up to HD 1080p video conferencing. Make a vivid impression with true-to-life, high definition video calls that allow for a 78-degree field of view - no more repositioning the camera to fit everyone in. Multiple mounting options and Plug-and-Play setup ensure ease of use right out of the box.
THE LOGITECH UC KEYBOARD K725-C FEATURES:
Revolutionary design integrates phone and video controlsManage audio and video calling experience including call answer/end, mute, voicemail and video camera on/off right from the keyboard. -
Built-in phone LCD screen
Displays incoming caller IDs, call length during call, date/time when not on a call, and more. -
Illuminated keys display call/video status
Get instant notification and status alerts for phone and video call controls. -
Logitech PerfectStroke key system
It makes every keystroke comfortable, fluid and whisper-quiet - perfect for the all-day worker. -
Integrated, corded design
It replaces the need for a desk phone, helping to save space on the shrinking desktop. -
M525-C WIRELESS MOUSE FEATURES:
Ergonomic design with soft rubber gripsProvide support and help to ease hand strain for all-day comfort. -
Micro-precise scroll wheel
With more wheel grooves per millimeter, scrolling through long documents and web pages is faster and easier. -
Advanced 2.4 GHz wireless technology
Get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts. -
Advanced optical tracking technology
Laser-grade precision technology tracks on surfaces that are normally problematic for standard optical mice. -
Small receiver inconspicuously connects to the USB port on the keyboard, freeing a USB port on your PC. -
C920-C WEBCAM FEATURES:
1080p HD video at up to 30 frames per secondMake a vivid impression with true-to-life, high definition video calls. -
78-degree field of view with true widescreen
See more without having to reposition the camera or crop and zoom. -
UVC H.264 encoding technology
It frees up system bandwidth by putting video processing within the camera. -
Logitech RightLight 2 technology and autofocus
Webcam intelligently adjusts to improve visual quality in low light and backlit situations at multiple distances. -
Omni-directional dual stereo microphones
It is designed to capture sound for clear communication in larger spaces like offices and small conference rooms. -
Freedom to mount the camera wherever it works best - LCD screen, notebook, or tabletop - by using the attached clip or the tripod embedded thread.
- Logitech UC Solution for Cisco 725-C - keyboard and mouse set - with Logitech C920-C Webcam
- Keyboard and mouse set
- Interface
- USB
- Connectivity Technology
- Wired
- LCD display
- Pointing Device
- Mouse - optical
- Buttons Qty
- 5
- Scrolling wheel, on/off power switch, 1000 dpi resolution, battery indicator
- 3-year warranty
- Bundled with
- Logitech C920-C Webcam
- Interface
- USB
- Dimensions (WxDxH) / Weight
- Keyboard: 44.2 cm x 16.2 cm x 3.2 cm / 0.9 kg , Mouse: 10.2 cm x 5.7 cm x 3.9 cm / 122.4 g
- Bundled with
Input Device
- Keyboard Name
- Logitech UC Keyboard K725-C
- LCD display
Pointing Device
- Mouse
- Pointing Device Name
- Logitech M525-C Wireless Mouse
- Buttons Qty
- 5
- Movement Detection Technology
- Optical
- Pointing Device Features
- Cables Included
- 1 x USB cable - 2 m
- UL, VCCI, C-Tick, GS, CB, FCC, RoHS, KCC, WEEE, GOST-R, TUV T
- Limited warranty - 3 years
