Logitech Logitech Mobile Speakerphone P710e - Speakerphone hands-free
Quicklinx: 9R77WS00 Mfr#: 980-000742
Stock Status: Used Stock
£79.35 ex VAT
£95.22 inc VAT
Elevate audio quality to an "I can't tell you're on a speakerphone" experience - with freedom from holding a phone to your ear. Advanced DSP technology enables precise tuning for both the microphone and speaker so conversations are more life-like. An integrated stand positions a mobile phone or tablet at just the right angle for shake-free video calls and hands-free access to the mobile screen. Hear and be heard in true wideband audio, so those on both sides of the call can enjoy a life-like communication experience. Plug a headphone directly into the Mobile Speakerphone P710e when additional privacy is desired.
  • FLEXIBLE HANDS-FREE CONFERENCING
    For the multitasking professional, the Logitech P710e speakerphone lets you instantly connect and start a video conference using your mobile device. The P710e holds your device steady for undisturbed visibility on the other end of the call while you take notes or type on a second device or computer
  • TAKE THE MOBILE P710E ANYWHERE
    When you need to take a call in a busy office, at home, or in a hotel room, the P710e speakerphone provides long battery life with up to 15 hours of talk time. A custom speaker and noise-cancelling mic offer clear sound on both ends of the call. Plug headphones into the P710e for additional privacy
  • CONNECT INSTANTLY TO A MEETING
    When you're ready to jump on a call, connect your mobile phone or tablet to the P710e speakerphone using Bluetooth with optional NFC pairing or the attached USB cable. Pair up to eight Bluetooth devices. Easily pair and unpair NFC-enabled mobile devices to the P710e by simply touching them together
  • DESIGNED FOR BUSINESS
    Video conferencing is easy with the P710e. Optimized for Microsoft Lync , Cisco compatible1, and certified for Skype and Skype for Business, the P710e provides enterprise-quality audio and an integrated conferencing experience
  • INTEGRATED STAND
  • NOISE & ECHO CANCELLATION
    With acoustic echo cancellation and a noise-cancelling microphone, P710e is optimized so you can hear and be heard, even in noisy workspaces
  • LONG BATTERY LIFE
    Up to 15 hours of talk time between charges the Mobile Speakerphone P710e outlasts the longest workday
  • OPTIMIZED FOR VOICE AND MUSIC
    A dynamic equalizer automatically switches between voice and music modes, delivering the best sound quality for what the user is listening to
  • TOUCH CONTROLS
    Touch controls with LED indicators provide excellent response without transmitting audible noise through the audio path
  • INTEGRATED USB CABLE
    The USB cable is hardwired into the speakerphone so it's never lost and neatly coils away beneath the unit when not in use
Logitech Mobile Speakerphone P710e - speakerphone
Speakerphone - Bluetooth - wireless, wired - NFC
Recommended Use
Portable electronics, computer - communication
Additional Functions
LED lights
Wireless, wired
Wireless Technology
Bluetooth
Audio Specifications
Frequency Response 140 - 16000 Hz
Microphone
Built-in
Microphone Operation Mode
Omni-directional
Controls
Volume, answer/end
LED lights
12 cm
12 cm
4 cm
275 g
Recommended Use
Audio Output
Wireless, wired
Wireless Technology
Bluetooth
Frequency Response
140 - 16000 Hz
Dynamic Range
85 dB
Microphone
Omni-directional
Directivity Angle
360°
Frequency Response
50 - 8000 Hz
Remote Control
Controls
Volume, answer/end
Connector Type
USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
Carrying case, spacer
Cable Details
USB cable
Power adapter - external
Speaker phone battery rechargeable
Run Time (Up To)
15 hour(s)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9R77 042768
Condition: This item has been opened and used. It shows signs of use.
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £58.62
Ref: 9R77 042769
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Logitech
Price Range Ex VAT: 50 - 100
