Logi BASE uses Apple Smart Connector technology to bring you a new charging experience. BASE gives your iPad Pro the perfect spot to recharge in any room of the house - and while you're using it too. It has magnets in the charging cradle to perfectly align iPad Pro with the Smart Connector. The Smart Connector has a minimal profile that makes it effortless to place your iPad Pro in the charging position. Just place your iPad Pro on BASE and it begins to charge.
Logi BASE gives you an ideal viewing angle to use your iPad Pro on a table or countertop anywhere in the house. Set your iPad Pro on BASE in the kitchen to follow your favorite recipes. Say "Hey, Siri " and ask for hands free help to set a timer, convert tablespoons into cups or cups into ounces, or make a FaceTime call to your mom when you get completely lost in a recipe. Set your BASE in the bedroom and make your morning routine a breeze. With a "Hey, Siri" you can check the weather, your schedule, and crank your favorite morning tunes, all hands free. BASE also works great on your desk, allowing you to use your iPad Pro as an extension of your laptop or desktop screen.
SLEEK, MODERN DESIGN
Made from the highest quality, premium aluminum, BASE complements your iPad Pro and looks great with your Mac . Recognized for its outstanding design, BASE has received four design awards and international acclaim -
EASIEST WAY TO CHARGE YOUR IPAD PRO
With the latest generation of connectivity-Apple Smart Connector, simply place your iPad into the cradle and charging will begin instantly. Magnets hold your iPad securely in place -
PERFECT VIEWING ANGLE
BASE holds your iPad Pro at a 70-degree angle that's perfect for watching movies, reading recipes, or making FaceTime calls -
BUILT FOR STABILITY
A weighted foot, curve-shaped design, and anti-slip pad provide sturdy, rock-solid support with surface grip. Even the largest of iPads won't tip over -
USEFUL IN EVERY ROOM WITH SIRI
Set BASE anywhere in your home-kitchen, office, bedroom or living room. Ask Siri to look up a recipe while you cook in the kitchen, set an alarm before you go to bed, or play your favorite tunes for a spontaneous dance party in the living room. The possibilities are endless -
HEY, SIRI
Make your morning routine a breeze. With a "Hey, Siri" you can check the weather, set reminders, and review your calendar, all hands-free -
DESIGNED IN COLLABORATION WITH APPLE
We designed BASE specifically for the iPad Pro. Enjoy the latest technology and functionality in a design that complements your iPad or Mac -
SCRATCH-FREE DOCKING
BASE has a thin polycarbonate layer at the contact points of iPad to ensure scratch-free docking -
MFi CERTIFIED
MFi certification means that BASE fully adheres to safety and quality requirements set by Apple -
1-YEAR WARRANTY
We stand behind our products and commitment to excellence. If you need help with a product, our Customer Care team is happy to help. Learn more about our product warranties
- Logitech BASE charging stand - Smart Connector
- Product Type
- Charging stand
- 17.8 cm x 11.4 cm x 8.2 cm
- 357 g
- Output Connector Type
- Smart Connector
- Max Electric Current
- 2.4 A
- 2-year warranty
- Designed For
- Apple 10.2-inch iPad (7th generation); 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro; 12.9-inch iPad Pro (1st generation, 2nd generation); 9.7-inch iPad Pro
- Product Type
- Charging stand
- Designed For
- Tablet
- 17.8 cm
- 11.4 cm
- 8.2 cm
- 357 g
- Input Connectors
- Apple Lightning
- Input Connectors Qty
- 1
- Output connectors
- Apple Smart Connector
- 2.4 A
- AC Power Adaptor Required
- Magnetic connector
- Material
- Aluminium
- Limited warranty - 2 years
- Designed For
- Apple 10.2-inch iPad (7th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad Pro
