Logitech Keyboard K120
Quicklinx: 8NDWWS00 Mfr#: 920-002509
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
£11.56 ex VAT
£13.87 inc VAT
Your hands will enjoy the low-profile, whisper-quiet keys and standard layout with full-size F-keys and number pad. The slim keyboard isn't just sleek-it's tough with a spill-resistant design, sturdy tilt legs and durable keys. You simply plug it into a USB port on your desktop, laptop or netbook computer and start using it right away.
  • Comfortable, quiet typing
    You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound and standard layout with full-size F-keys and number pad.
  • Spill-resistant design
    Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills.
  • Thin profile
    The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
  • Durable keys
    The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits.
  • Sturdy, adjustable tilt legs
    You can extend the sturdy folding legs to increase the keyboard tilt by 8 degrees to address your personal ergonomic needs.
  • Plug-and-play USB connection
    Setup is simple-you just plug it into a USB port on your desktop, laptop or netbook computer and start using it right out of the box.
  • Easy-to-read keys
    The bold, bright white characters make the keys easier to read-perfect for those with less-than-perfect vision. They're less likely to wear off, too.
  • Curved space bar
    It keeps your hands in a more natural position so you can type in greater comfort.
Logitech K120 - keyboard - US Input Device
Keyboard
USB
Wired
Localization and Layout
US
Spillproof
45 cm x 15.5 cm x 2.4 cm
0.55 kg
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
USB
US
Spillproof
45 cm
15.5 cm
2.4 cm
0.55 kg
1 x USB cable - 1.5 m
Plug and Play, UL, TUV, VCCI, BSMI, cUL, FCC, KCC, WEEE
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
