Logitech K800 Wireless Illuminated Keyboard
Quicklinx: 7HSWWS00 Mfr#: 920-002382
Recommended Use: Leisure, Office
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
£75.68 ex VAT
£90.81 inc VAT
The sleek, comfortable keyboard delivers a brilliant typing experience - day or night. With automatic backlighting and hand proximity detection this sleek, comfortable keyboard delivers a brilliant typing experience - day or night.
You can work or play anytime with laser-etched, backlit keys that are bright enough to let you type in the dark. Your desk is about to get sleeker thanks to the thin profile, clear edge, and streamlined, wireless design.
Every stroke you make is comfortable, fluid, and whisper-quiet with the PerfectStroke key system. You can type easily - even in the dark - with brightly backlit keys that provide precise illumination. Only the characters are illuminated, so you can see just what you need to see without distraction.
  • Laser-etched, backlit keys
    You can type easily-even in the dark-with brightly backlit keys that provide precise illumination. Only the characters are illuminated, so you can see just what you need to see without distraction
  • Adjustable backlighting
    The keyboard automatically adjusts the backlighting to suit the lighting conditions. Or you can adjust it the way you like it with the press of a button
  • Hand proximity detection
    Sensors detect your hands as they approach the keyboard to turn the backlight on and off
  • PerfectStroke key system
    The PerfectStroke key system distributes typing force evenly across key surfaces, making every keystroke comfortable, fluid, and whisper-quiet
  • Logitech Incurve keys
    Durable concave keys position your fingers properly, and their softly rounded edges invite your fingertips to glide from key to key, hour after hour
  • Fast, easy recharging
    You simply plug in the universal micro-USB cable for three to six hours for up to 10 days of battery life. You can even type while it's recharging
  • Sleek, streamlined design
    With sleek lines, a clear edge, and low-profile keys, the keyboard adds style to your workspace-whether you've got a laptop or desktop
  • Logitech Unifying receiver
    The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard-without the hassle of multiple USB receivers
  • Logitech Advanced 2.4 GHz wireless
    So you can work or play in more places-like your comfy couch-the long-range wireless connection virtually eliminates delays, dropouts, and interference
  • Easy storage
    You can store your keyboard standing up to free up space on your desk
  • Power management
    An on/off switch helps you go longer between charges, while power indicator lights eliminate surprises
  • Easy wireless setup
    You simply plug the wireless receiver into a USB port on your desktop PC or laptop for a fast, reliable connection right out of the box
  • Full-size layout
    All the keys are right where you're used to so you can type quickly and comfortably
  • Lighting the way
  • Shines on your desk
  • Happy tapping
  • More power
    You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it. Learn more about the Logitech Unifying receiver
Logitech Wireless Illuminated Keyboard K800 - keyboard - UK
Keyboard
Backlit
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
PerfectStroke, Logitech Incurve keys, Logitech Unifying receiver
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
Backlit
2.4 GHz
Wireless Receiver
Input Device
Wireless
1 x USB charge cable , 1 x USB extension cable
Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
Recommended Use: Office
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
Price Range Ex VAT: 50 - 100
