This clever little keyboard has all the standard keys - so you can save lots of space without missing a thing. The reliable wireless connection lets you work or play up to 10 meters away with virtually no delays or dropouts.
Much smaller design, same keys
The compact keyboard is about 36% smaller than our standard keyboards but still has all the standard keys-so doing the things you love is as easy as ever -
Advanced 2.4 GHz wireless
So you can work or play in more places-like your comfy couch-the wireless connection virtually eliminates delays, dropouts and interference and gives you range of up to 10 meters (33 feet) -
Connect with ease
You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it -
128-bit AES encryption
It helps protect your information by encrypting data transfer between the keyboard and receiver with one of the highest levels of data encryption available -
2-year battery life
With the extended battery life and auto-sleep, you can write Facebook updates, emails and Yelp reviews for years without the hassle of changing batteries -
Sleek, customizable design
The battery door on top of the keyboard doubles as a fun design element with light gray, pink and blue options you can swap in to suit your mood or décor -
Plug-and-play simplicity
Setup couldn't be easier-you simply plug the wireless receiver into a USB port on your computer and start tweeting , blogging and IMing right away without software -
Whisper-quiet keys
The keys barely make a sound, so you can hear the song you're listening to and not what you're typing -
Super space saver
This clever little keyboard has all the standard keys-so you can save lots of space without missing a thing -
Free to roam
The reliable wireless connection lets you work or play up to 10-meters (33 feet) away with virtually no delays or dropouts -
Power up for years (2-year battery life)
With a 2-year battery life and auto-sleep, you can catch up on Facebook, email friends and tweet on Twitter for years without the hassle of changing batteries
- Logitech Wireless Keyboard K230 - keyboard - UK
- Keyboard
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Hot Keys Function
- Volume, mute
- 38 cm x 11.2 cm x 1.8 cm
- 320 g
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Keyboard
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
Input Device
- Wireless
- Hot Keys Function
- Volume, mute
- UK
- Keyboard Technology
- Membrane
- 38 cm
- 11.2 cm
- 1.8 cm
- 320 g
- Included Accessories
- 3 battery doors
- Plug and Play, AES-128
- OS Required
- Microsoft Windows Vista / XP / 7
- AAA type
- Installed Qty
- 2
- Limited warranty - 3 years
